[Geoserver-devel] [JIRA] (GEOS-9867) 2.18.x GeoServer startup failure with 19JAN21 COG extension
Andy Arismendi created an issue
GeoServer / BugGEOS-9867
Issue Type:
BugBug
Affects Versions:
2.18.1
Assignee:
Unassigned
Components:
Community modules
Created:
19/Jan/21 8:19 PM
Priority:
MediumMedium
Reporter:
Andy Arismendi
Service 503 after startup attempt. Stacktrace error is below.
GeoServer Version
version = 2.18-SNAPSHOT
git revision = 4f27a36677fe1c75d115bde8365a8f2e2dfe5efa
git branch = origin/2.18.x
build date = 19-Jan-2021 04:11
geotools version = 24-SNAPSHOT
geotools revision = ac1aebd80411701441f87a828742d3e6f3094391
geowebcache version = 1.18-SNAPSHOT
geowebcache revision = 3874836782d91999b187400568f6aa0148cb4dfc/38748
hudson build = -1
COG Extension Version
Manifest-Version: 1.0
Application-Name:
Implementation-Title: COG support module
Implementation-Version: 2.18-SNAPSHOT
Build-Timestamp: 19-Jan-2021 04:11
Archiver-Version: Plexus Archiver
Built-By: jenkins
Specification-Vendor: Open Source Geospatial Foundation
Specification-Title: COG support module
Implementation-Vendor-Id: org.geoserver.community
GeoServerModule: community
Project-Version: 2.18-SNAPSHOT
Implementation-Vendor: Open Source Geospatial Foundation
Iteration-Name:
Git-Revision: 4f27a36677fe1c75d115bde8365a8f2e2dfe5efa
Created-By: Apache Maven 3.6.3
Build-Jdk: 1.8.0_212
Specification-Version: 2.18-SNAPSHOT
GeoServer Log
2021-01-19 14:09:06,233 ERROR [context.ContextLoader] - Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘requestMappingHandlerAdapter’ defined in org.geoserver.rest.RestConfiguration: Bean instantiation via factory method failed; nested exception is org.springframework.beans.BeanInstantiationException: Failed to instantiate [org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter]: Factory method ‘requestMappingHandlerAdapter’ threw exception; nested exception is java.lang.NoClassDefFoundError: com/fasterxml/jackson/annotation/JsonView
at org.springframework.beans.factory.support.ConstructorResolver.instantiate(ConstructorResolver.java:627)
at org.springframework.beans.factory.support.ConstructorResolver.instantiateUsingFactoryMethod(ConstructorResolver.java:456)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.instantiateUsingFactoryMethod(AbstractAutowireCapableBeanFactory.java:1320)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:1159)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:555)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:515)
at org.springframework.beans.factory.support.AbstractBeanFactory.lambda$doGetBean$0(AbstractBeanFactory.java:320)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:226)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:318)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:199)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:860)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:878)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:550)
at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:401)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:292)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:103)
at org.geoserver.platform.GeoServerContextLoaderListener.contextInitialized(GeoServerContextLoaderListener.java:22)
at org.eclipse.jetty.server.handler.ContextHandler.callContextInitialized(ContextHandler.java:957)
at org.eclipse.jetty.servlet.ServletContextHandler.callContextInitialized(ServletContextHandler.java:553)
at org.eclipse.jetty.server.handler.ContextHandler.startContext(ContextHandler.java:922)
at org.eclipse.jetty.servlet.ServletContextHandler.startContext(ServletContextHandler.java:365)
at org.eclipse.jetty.webapp.WebAppContext.startWebapp(WebAppContext.java:1497)
at org.eclipse.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1459)
at org.eclipse.jetty.server.handler.ContextHandler.doStart(ContextHandler.java:852)
at org.eclipse.jetty.servlet.ServletContextHandler.doStart(ServletContextHandler.java:278)
at org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:545)
at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:68)
at org.eclipse.jetty.deploy.bindings.StandardStarter.processBinding(StandardStarter.java:46)
at org.eclipse.jetty.deploy.AppLifeCycle.runBindings(AppLifeCycle.java:192)
at org.eclipse.jetty.deploy.DeploymentManager.requestAppGoal(DeploymentManager.java:502)
at org.eclipse.jetty.deploy.DeploymentManager.addApp(DeploymentManager.java:151)
at org.eclipse.jetty.deploy.providers.ScanningAppProvider.fileAdded(ScanningAppProvider.java:172)
at org.eclipse.jetty.deploy.providers.WebAppProvider.fileAdded(WebAppProvider.java:416)
at org.eclipse.jetty.deploy.providers.ScanningAppProvider$1.fileAdded(ScanningAppProvider.java:65)
at org.eclipse.jetty.util.Scanner.reportAddition(Scanner.java:610)
at org.eclipse.jetty.util.Scanner.reportDifferences(Scanner.java:529)
at org.eclipse.jetty.util.Scanner.scan(Scanner.java:392)
at org.eclipse.jetty.util.Scanner.doStart(Scanner.java:313)
at org.eclipse.jetty.deploy.providers.ScanningAppProvider.doStart(ScanningAppProvider.java:145)
at org.eclipse.jetty.deploy.DeploymentManager.startAppProvider(DeploymentManager.java:576)
at org.eclipse.jetty.deploy.DeploymentManager.doStart(DeploymentManager.java:238)
at org.eclipse.jetty.util.component.ContainerLifeCycle.start(ContainerLifeCycle.java:167)
at org.eclipse.jetty.server.Server.start(Server.java:418)
at org.eclipse.jetty.util.component.ContainerLifeCycle.doStart(ContainerLifeCycle.java:119)
at org.eclipse.jetty.server.handler.AbstractHandler.doStart(AbstractHandler.java:113)
at org.eclipse.jetty.server.Server.doStart(Server.java:382)
at org.eclipse.jetty.xml.XmlConfiguration$1.run(XmlConfiguration.java:1572)
at org.eclipse.jetty.xml.XmlConfiguration$1.run(XmlConfiguration.java:1512)
at java.base/java.security.AccessController.doPrivileged(Native Method)
at org.eclipse.jetty.xml.XmlConfiguration.main(XmlConfiguration.java:1511)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.base/java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.jetty.start.Main.invokeMain(Main.java:220)
at org.eclipse.jetty.start.Main.start(Main.java:490)
at org.eclipse.jetty.start.Main.main(Main.java:77)
Caused by: org.springframework.beans.BeanInstantiationException: Failed to instantiate [org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter]: Factory method ‘requestMappingHandlerAdapter’ threw exception; nested exception is java.lang.NoClassDefFoundError: com/fasterxml/jackson/annotation/JsonView
at org.springframework.beans.factory.support.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:185)
at org.springframework.beans.factory.support.ConstructorResolver.instantiate(ConstructorResolver.java:622)
… 60 more
Caused by: java.lang.NoClassDefFoundError: com/fasterxml/jackson/annotation/JsonView
at com.fasterxml.jackson.databind.introspect.JacksonAnnotationIntrospector.<clinit>(JacksonAnnotationIntrospector.java:37)
at com.fasterxml.jackson.databind.ObjectMapper.<clinit>(ObjectMapper.java:350)
at org.springframework.http.converter.json.Jackson2ObjectMapperBuilder.build(Jackson2ObjectMapperBuilder.java:631)
at org.springframework.http.converter.json.MappingJackson2HttpMessageConverter.<init>(MappingJackson2HttpMessageConverter.java:59)
at org.springframework.http.converter.support.AllEncompassingFormHttpMessageConverter.<init>(AllEncompassingFormHttpMessageConverter.java:76)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.<init>(RequestMappingHandlerAdapter.java:209)
at org.springframework.web.servlet.config.annotation.WebMvcConfigurationSupport.createRequestMappingHandlerAdapter(WebMvcConfigurationSupport.java:594)
at org.springframework.web.servlet.config.annotation.WebMvcConfigurationSupport.requestMappingHandlerAdapter(WebMvcConfigurationSupport.java:562)
at org.geoserver.rest.RestConfiguration$$EnhancerBySpringCGLIB$$20637a5.CGLIB$requestMappingHandlerAdapter$28(<generated>)
at org.geoserver.rest.RestConfiguration$$EnhancerBySpringCGLIB$$20637a5$$FastClassBySpringCGLIB$$15fd98a3.invoke(<generated>)
at org.springframework.cglib.proxy.MethodProxy.invokeSuper(MethodProxy.java:244)
at org.springframework.context.annotation.ConfigurationClassEnhancer$BeanMethodInterceptor.intercept(ConfigurationClassEnhancer.java:363)
at org.geoserver.rest.RestConfiguration$$EnhancerBySpringCGLIB$$20637a5.requestMappingHandlerAdapter(<generated>)
at org.springframework.beans.factory.support.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:154)
… 61 more
Caused by: java.lang.ClassNotFoundException: com.fasterxml.jackson.annotation.JsonView
at java.base/java.net.URLClassLoader.findClass(Unknown Source)
at java.base/java.lang.ClassLoader.loadClass(Unknown Source)
at org.eclipse.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoader.java:555)
… 79 more
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100154-sha1:34dd3c4)
Atlassian logo
