Targeting this postWorkspace method in workspaces.yaml ,
post:
operationId: postWorkspaces
tags:
- "Workspaces"
summary: add a new workspace to GeoServer
description: Adds a new workspace to the server
security:
- basic: []
parameters:
- name: workspaceBody
description: The layer group body information to upload.
in: body
required: true
schema:
$ref: "#/definitions/Workspace"
- name: default
in: query
description: New workspace will be the used as the default. Allowed values are true or false, The default value is false.
required: false
type: boolean
default: false
consumes:
- application/json
- application/xml
produces:
- text/html
- application/json
- application/xml
responses:
201:
description: Created
schema:
type: string
headers:
description: URL where the newly created workspace can be found
type: string
401:
description: Unable to add workspace as it already exists
That has this definition (schema) for the Workspace :
definitions:
Workspace:
title: Workspace
xml:
type: object
properties:
name:
type: string
description: name of the workspace
I asked Swagger 2.0 to generate for me a REST API Client. A simple test allow to run it, then.
public void createWorkspace()
{ Workspace workspace = new Workspace(); workspace.setName("ecoemploi"); WorkspacesApi workspacesApi = new WorkspacesApi(apiClient()); String response = workspacesApi.postWorkspaces(workspace, true); }
This client sends a JSON body to the GeoServer REST API that is similar to this curl :
`curl -v -u admin:geoserver -XPOST -H “Content-type:text/json” -d "
{ name: ‘ecoemploi’ }
" http://localhost:8080/geoserver/rest/workspaces`
and makes it fail :
29 janv. 15:09:55 TRACE [org.geoserver.platform.resource] - polling contents of /home/marc/geoserver-2.18.2-bin/data_dir/gwc-layers
29 janv. 15:09:55 TRACE [org.geoserver.platform.resource] - delta computed in 329us for /home/marc/geoserver-2.18.2-bin/data_dir/gwc-layers
29 janv. 15:09:59 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/workspaces, QueryString: default=true'; against '/web/**'
29 janv. 15:09:59 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/workspaces, QueryString: default=true'; against '/gwc/rest/web/**'
29 janv. 15:09:59 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/workspaces, QueryString: default=true'; against '/'
29 janv. 15:09:59 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/workspaces, QueryString: default=true'; against '/j_spring_security_check'
29 janv. 15:09:59 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/workspaces, QueryString: default=true'; against '/j_spring_security_check/'
29 janv. 15:09:59 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/workspaces, QueryString: default=true'; against '/j_spring_security_logout'
29 janv. 15:09:59 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/workspaces, QueryString: default=true'; against '/j_spring_security_logout/'
29 janv. 15:09:59 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/workspaces, QueryString: default=true'; against '/rest/**'
29 janv. 15:09:59 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /rest/workspaces, QueryString: default=true with /rest/**
29 janv. 15:09:59 DEBUG [org.geoserver.security] - AuthenticationCache has no entry for basic, admin:bfa584f5598433a3c1fe16b00acc9c43
29 janv. 15:09:59 DEBUG [org.geoserver.security.rememberme.GeoServerTokenBasedRememberMeServices] - Did not send remember-me cookie (principal did not set parameter '_spring_security_remember_me')
29 janv. 15:09:59 DEBUG [org.geoserver.security.rememberme.GeoServerTokenBasedRememberMeServices] - Remember-me login not requested.
29 janv. 15:09:59 DEBUG [org.geoserver.security] - AuthenticationCache adding new entry for basic, admin:bfa584f5598433a3c1fe16b00acc9c43
29 janv. 15:09:59 DEBUG [org.geoserver.security] - Cache entries #: 0
29 janv. 15:09:59 DEBUG [org.geoserver.security] - AuthenticationCache added new entry for basic, admin:bfa584f5598433a3c1fe16b00acc9c43
29 janv. 15:09:59 DEBUG [org.geoserver.security] - Cache entries #: 1
29 janv. 15:09:59 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Converted URL to lowercase, from: '/rest/workspaces'; to: '/rest/workspaces' and httpMethod= POST
29 janv. 15:09:59 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /** methodList= [GET]
29 janv. 15:09:59 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/workspaces'; antPath is /**; matchedPath=true; matchedMethods=false
29 janv. 15:09:59 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /** methodList= [POST, DELETE, PUT]
29 janv. 15:09:59 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/workspaces'; antPath is /**; matchedPath=true; matchedMethods=true
29 janv. 15:09:59 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - returning ADMIN
29 janv. 15:09:59 DEBUG [org.geoserver] - Thread 23 locking in mode WRITE
29 janv. 15:09:59 DEBUG [org.geoserver] - Thread 23 got the lock in mode WRITE
29 janv. 15:09:59 ERROR [org.geoserver.rest] - name
com.thoughtworks.xstream.mapper.CannotResolveClassException: name
at com.thoughtworks.xstream.mapper.DefaultMapper.realClass(DefaultMapper.java:81)
at com.thoughtworks.xstream.mapper.MapperWrapper.realClass(MapperWrapper.java:125)
at com.thoughtworks.xstream.mapper.DynamicProxyMapper.realClass(DynamicProxyMapper.java:55)
at com.thoughtworks.xstream.mapper.PackageAliasingMapper.realClass(PackageAliasingMapper.java:88)
at com.thoughtworks.xstream.mapper.ClassAliasingMapper.realClass(ClassAliasingMapper.java:79)
at com.thoughtworks.xstream.mapper.ArrayMapper.realClass(ArrayMapper.java:74)
at com.thoughtworks.xstream.mapper.SecurityMapper.realClass(SecurityMapper.java:71)
at org.geoserver.config.util.SecureXStream$DetailedSecurityExceptionWrapper.realClass(SecureXStream.java:490)
at com.thoughtworks.xstream.mapper.CachingMapper.realClass(CachingMapper.java:47)
at com.thoughtworks.xstream.core.util.HierarchicalStreams.readClassType(HierarchicalStreams.java:29)
at com.thoughtworks.xstream.core.TreeUnmarshaller.start(TreeUnmarshaller.java:133)
at com.thoughtworks.xstream.core.AbstractTreeMarshallingStrategy.unmarshal(AbstractTreeMarshallingStrategy.java:32)
at com.thoughtworks.xstream.XStream.unmarshal(XStream.java:1487)
at com.thoughtworks.xstream.XStream.unmarshal(XStream.java:1467)
at com.thoughtworks.xstream.XStream.fromXML(XStream.java:1347)
at org.geoserver.config.util.XStreamPersister.load(XStreamPersister.java:665)
at org.geoserver.rest.converters.XStreamJSONMessageConverter.readInternal(XStreamJSONMessageConverter.java:60)
at org.springframework.http.converter.AbstractHttpMessageConverter.read(AbstractHttpMessageConverter.java:199)
at org.springframework.web.servlet.mvc.method.annotation.AbstractMessageConverterMethodArgumentResolver.readWithMessageConverters(AbstractMessageConverterMethodArgumentResolver.java:206)
at org.springframework.web.servlet.mvc.method.annotation.RequestResponseBodyMethodProcessor.readWithMessageConverters(RequestResponseBodyMethodProcessor.java:158)
at org.springframework.web.servlet.mvc.method.annotation.RequestResponseBodyMethodProcessor.resolveArgument(RequestResponseBodyMethodProcessor.java:131)
at org.springframework.web.method.support.HandlerMethodArgumentResolverComposite.resolveArgument(HandlerMethodArgumentResolverComposite.java:127)
at org.springframework.web.method.support.InvocableHandlerMethod.getMethodArgumentValues(InvocableHandlerMethod.java:167)
at org.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:134)
at org.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:105)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandlerMethod(RequestMappingHandlerAdapter.java:893)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:798)
at org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:87)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:1040)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:943)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:1006)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:909)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:883)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:873)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1623)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:26)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1610)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:69)
at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:70)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:66)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:41)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:37)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:320)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:70)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:127)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:91)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:74)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:334)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:119)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:51)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilterInternal(BasicAuthenticationFilter.java:215)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:119)
at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:81)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:105)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:215)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:178)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:142)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:358)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:271)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:101)
at org.geoserver.filters.XFrameOptionsFilter.doFilter(XFrameOptionsFilter.java:77)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:53)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:46)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:42)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:201)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1602)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:540)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:146)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:257)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1700)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:255)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1345)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:203)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:480)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1667)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:201)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1247)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:144)
at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:220)
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:152)
at org.eclipse.jetty.server.Server.handle(Server.java:505)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:370)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:267)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:305)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103)
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:333)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:310)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:168)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:126)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:366)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:698)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:804)
at java.base/java.lang.Thread.run(Thread.java:834)
29 janv. 15:09:59 DEBUG [org.geoserver] - Thread 23 releasing the lock in mode WRITE
29 janv. 15:09:59 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
29 janv. 15:10:00 TRACE [org.geoserver.platform.resource] - polling contents of /home/marc/geoserver-2.18.2-bin/data_dir/gwc-layers
I noticed that GeoServer built a special receiver for REST request, based on XStream .
But it expect a customized JSON body where another imbrication of json is added with a “workspace:” attribute :
This curl will work :
curl -v -u admin:geoserver -XPOST -H "Content-type:text/json" -d "{workspace:{name:'ecoemploi' }} " [http://localhost:8080/geoserver/rest/workspaces](http://localhost:8080/geoserver/rest/workspaces)
and there’s an "xml:attribute in the yaml` file that is giving indication about that to a human reader.
definitions:
Workspace:
title: Workspace
xml:
type: object
properties:
name:
type: string
xml:
But this xml attribute isn’t a part of the OpenAPI (Swagger) 2.0 schema definition. Swagger generator won’t take it into account, and the yaml description of GeoServer seems ineffective to generate by this tool a working client.
Joined : test case, and a pom.xml to help setting the swagger client generator.
