[Geoserver-devel] [JIRA] (GEOS-9904) GeoFence backend DBMS dependencies
Emanuele Tajariol created an issue
GeoServer / ImprovementGEOS-9904
Issue Type:
ImprovementImprovement
Assignee:
Emanuele Tajariol
Components:
GeoFence
Created:
12/Feb/21 1:27 PM
Fix Versions:
2.19-RC
Priority:
MediumMedium
Reporter:
Emanuele Tajariol
The geofence-server module currently builds a zip file with the jars needed for working with geodb (h2) only.
In order to user postgis as a backend DBMS some manual work is required, and the needed jars are not included in the zip file. Note that we can’t include all the jars in a single plugin, because the hibernate-spatial jars will conflict.
The proposal is to:
  • transform geofence-server into a pom module
  • create a submodule of geofence-server, geofence-server-geodb, which creates a plugin with the required libraries for geodb
  • create a submodule of geofence-server, geofence-server-postgis, which creates a plugin with the required libraries for postgis.
  • It will inherit everything from geofence-server-geodb, with the exclusion of the hibernate and the jdbc dependencies, because it will have its own.
  • It will re-run the very same tests of geofence-server-geodb using pg as a backend
  • Tests will be enabled with a profile, bc they are integration tests that require a postgres service.
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100154-sha1:ae50352)
Atlassian logo
