[Geoserver-devel] [JIRA] (GEOS-9975) Cannot set netcdf-out settings through REST interface
Benjamin Root created an issue
GeoServer / BugGEOS-9975
Issue Type:
BugBug
Affects Versions:
2.17.2
Assignee:
Unassigned
Components:
NetCDF
Created:
12/Mar/21 6:59 PM
Environment:
amazon-linux2
Priority:
MediumMedium
Reporter:
Benjamin Root
I am trying to automate the process of deploying my GeoServer by using a script that takes advantage of the REST interface to configure the workspaces, datastores, etc, which is working fairly well at this point. I recently ran into a need to configure the netcdf-out plugin. If I GET /rest/settings, I get the following relevant portion:
{'global':
    {'settings':
        {'charset': 'utf-8',
         'contact': { ... snip ... },
         'id': 'SettingsInfoImpl-639a7ad2:17822c9dc27:-8000',
         'localWorkspaceIncludesPrefix': False,
         'metadata': {'map': [{'entry': {'netCDFSettings': {'compressionLevel': 0,
                                                            'copyAttributes': False,
                                                            'copyGlobalAttributes': False,
                                                            'dataPacking': 'NONE',
                                                            'shuffle': True},
                                                       'string': 'NetCDFOutput.Key' }} ]},
         'numDecimals': 0,
         'showCreatedTimeColumnsInAdminList': False,
         'showModifiedTimeColumnsInAdminList': False,
         'verbose': False,
         'verboseExceptions': False},
        ... snip ...
These are mostly perfectly normal default settings from a stock install of geoserver and the netcdf-out plugin (along with the native C netcdf libraries being loaded). As an experiment, I tried round-tripping the settings back through PUT /rest/settings. I get a response code of 500 and the response text is:
---- Debugging information ----
cause-exception     : java.lang.ClassCastException
cause-message       : class org.geoserver.web.netcdf.NetCDFSettingsContainer cannot be cast to class java.lang.String (org.geoserver.web.netcdf.NetCDFSettingsContainer is in unnamed module of loader org.apache.catalina.loader.ParallelWebappClassLoader @14ceb7e1; java.lang.String is in module java.base of loader 'bootstrap')
class               : org.geoserver.catalog.MetadataMap
required-type       : org.geoserver.catalog.MetadataMap
converter-type      : org.geoserver.config.util.XStreamPersister$SettingsTolerantMapConverter
line number         : -1
class[1]            : org.geoserver.config.impl.SettingsInfoImpl
required-type[1]    : org.geoserver.config.impl.SettingsInfoImpl
converter-type[1]   : org.geoserver.config.util.XStreamPersister$SettingsInfoConverter
class[2]            : org.geoserver.config.impl.GeoServerInfoImpl
required-type[2]    : org.geoserver.config.impl.GeoServerInfoImpl
converter-type[2]   : com.thoughtworks.xstream.converters.reflection.ReflectionConverter
version             : 2.17.2
So, it looks like some sort of serialization bug, I am guessing (I am a python programmer, not a java programmer, so I am groping in the dark here).
I did some digging through the geoserver codebase, and I found several tests that utilizes netCDFSettings as an invalid case (src/main/src/test/java/org/geoserver/config/util/XStreamPersisterTest.java), but no indication as to why they are invalid. The values used in those cases seems to correspond to the values in the given mapping – which are the defaults presented by geoserver itself! I could not find a single test that actually demonstrated a nominal round-trip of the netCDFSettings container through persistence.
This inability to set the netCDFSettings metadata actually becomes a roadblock in setting other things in settings, because if you don’t set anything for metadata in the REST PUT call, then that section of the settings gets clobbered. So, if I just wanted to set the contact information, I can’t ignore metadata or else it’ll get clobbered. But if I supply metadata, even with the default values, I get an error.
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100155-sha1:7f3163b)
Atlassian logo
