[Geoserver-devel] [JIRA] (GEOS-9979) GeoServer WMS cannot cache request if CQL_FILTER param contains percent sign
Yuan, Erhhung created an issue
GeoServer / BugGEOS-9979
Issue Type:
BugBug
Affects Versions:
2.18.2
Assignee:
Unassigned
Created:
17/Mar/21 8:56 PM
Environment:
Deployment via Helm chart from “kartoza/geoserver”
Priority:
MediumMedium
Reporter:
Yuan, Erhhung
Not sure if the issue is with GeoServer or GeoWebCache, but if I issue a WMS request containing the CQL_FILTER parameter whose value contains a percent sign, as in “property LIKE '%term%'”, GWC fails to cache the result and issues the geowebcache-miss-reason response header containing the exception (the correct image is served, just never cached), even though the entire WMS request is properly URL-encoded.
$ curl -v -o tile.png "http://example.com/geoserver/wms/service?format=image%2Fpng8&format_options=antialias%3Anone&env=color%3A00ff00%3Bopacity%3A0.5&cql_filter=filename%20like%20%27%25building%25%27&srs=EPSG%3A3857&transparent=true&exceptions=application%2Fvnd.ogc.se_xml&styles=test%3Apolygon&tiled=true&feature_count=101&service=WMS&version=1.1.1&request=GetMap&layers=test%3Alayer&bbox=-9092337.388578286%2C3546830.9864887483%2C-9092184.514521716%2C3546983.8605453186&width=256&height=256"
< HTTP/1.1 200
< X-Frame-Options: SAMEORIGIN
< Access-Control-Allow-Origin: *
< Set-Cookie: GS_FLOW_CONTROL=GS_CFLOW_-7d59bd29:1783ead6d08:-7ceb
< X-Control-flow-delay-ms: 0
< Cache-Control: max-age=3600, must-revalidate
< geowebcache-cache-result: MISS
< geowebcache-miss-reason: exception occurred: IllegalArgumentException: URLDecoder: Illegal hex characters in escape (%) pattern - Error at index 1 in: "bu"
< Expires: Wed, 17 Mar 2021 20:07:43 GMT
< Content-Disposition: inline; filename=test-layer.png
< Content-Type: image/png; mode=8bit
< Transfer-Encoding: chunked
< Date: Wed, 17 Mar 2021 19:07:43 GMT
If I reissue the same request such that I intentionally double URL-encode the percent sign so that “%25” becomes “%2525”, then it works.
... &cql_filter=filename%20like%20%27%2525building%2525%27& ...
I’m not sure if GeoServer, when directly integrated with GWC, relays the request internally through HTTP but fails to re-encode the query parameters, or something else, but the client side should not have to resort to double URL-encoding of percent signs.
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100155-sha1:4f39905)
Atlassian logo
