Gabriel Roldan created an issue |
Issue Type: |
Task |
Assignee: |
Created: |
23/Mar/21 11:20 PM |
Priority: |
Medium |
Reporter: |
A GeoServer REST API Java client library based on Includes OpenAPI 3 definition files for GeoServer’s REST API v1. As a difference with the legacy Swagger 2 definitions, these ones focus only in inter-process This API is developed using the Swagger 2 files as base, but carefully inspecting GeoServer’s REST config server implementation, often debugging it, in order to comply with the actual API as much as possible. The generated code produces two libraries:
Finally, the |
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS |
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100156-sha1:fdbe273) |
