I tried to add a jira bug to geotools, and got this error:
# Form Errors: Your evaluation of JIRA has expired, you will not be
able to create any more issues. If you are enjoying using JIRA, please
consider purchasing it - Jira | Issue & Project Tracking Software | Atlassian
Is this a confluence or codehaus bug? Do I need to do something?
dave
I noticed that the filter parser test (ParserTest) cases only tested to
see if the filter was parsed w/o throwing an exception - it doesnt
actually test to see if it builds a correct filter. It should probably
check this - especially if there's going to be a new Filter parser
implementation.
test9 had an invalid test .xml -- I fixed this.
This mail sent through IMP: https://webmail.limegroup.com/
