On Mon, Dec 21, 2015 at 12:33 PM, Ben Caradoc-Davies <ben@anonymised.com>
wrote:
I see no tag for 2.7.5 in GitHub nor a call for artifact testing. Are you
sure this issue was omitted? In the release procedure, release in Jira is
the first step. If the steps were performed out of order and you are sure
2.7.5 has been tagged successfully, then 2.7.6 is fine if you are sure your
issue is not fixed in 2.7.5.
The "first step" has been skipped for months, the others are carried out in
sequence, starting from a fixed revision,
provided as a parameter to the build server
That is the revision that gets tagged when performing "release publish",
which is the very last step in the release process.
Ian has already made the testing artifacts based on that revision.
If you have doubts other have made mistakes here is a procedure for you to
double check that,
without publicly pointing fingers, wasting other people time, and keep on
advancing doubts even
when the others tell you it's fine:
* Get the testing artifacts (the bin one)
* Unpack them locally
* Grab one GeoServer jar, reach for META-INF/MANIFEST.MF and get the
revision out of it:
Manifest-Version: 1.0
Build-Timestamp: 19-Dec-2015 11:32
Implementation-Title: REST Configuration Service Module
Implementation-Version: 2.7.5
*Git-Revision: 26f0e9f908fcc279652e0c2622db1028469be16e*
Built-By: jenkins
Specification-Vendor: The Open Planning Project
Application-Name:
GeoServerModule: core
Created-By: Apache Maven 3.0.4
Implementation-Vendor: The Open Planning Project
Iteration-Name:
Implementation-Vendor-Id: org.geoserver
Build-Jdk: 1.7.0_51
Project-Version: 2.7.5
Specification-Title: REST Configuration Service Module
Specification-Version: 2.7.5
Archiver-Version: Plexus Archiver
As an alternative, reach to the build job used to build the artifacts
and check its parameters:
http://ares.boundlessgeo.com/jenkins/view/release/job/geoserver-release/91/parameters/
Now that you have the revision, compare with the commit logs on 2.7.x:
https://github.com/geoserver/geoserver/commits/2.7.x
So yes, the commit is not in 2.7.5 and the ticket it's thus correctly
tagged for 2.7.6 (unless Ian needs to rebuild from a newer revision, but
it does not seem that's the case).
*Geosolutions' Winter Holidays from 24/12 to 6/1*
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
