[Geoserver-devel] [jira] Reopened: (GEOS-124) FeatureTypeEditor: SRS and Bounding box
Message:
   The following issue has been reopened.
   Reopener: Richard Gould
       Date: Tue, 13 Apr 2004 6:04 PM
(first bug isn't fixed yet)
View the issue:
  http://jira.codehaus.org/secure/ViewIssue.jspa?key=GEOS-124
Here is an overview of the issue:
        Key: GEOS-124
    Summary: FeatureTypeEditor: SRS and Bounding box
       Type: Bug
     Status: Reopened
   Priority: Major
Original Estimate: Unknown
Time Spent: Unknown
  Remaining: Unknown
    Project: GeoServer
   Fix Fors:
             1.2.0
   Versions:
             1.2-beta
   Assignee: Richard Gould
   Reporter: Richard Gould
    Created: Tue, 16 Mar 2004 4:27 PM
    Updated: Tue, 13 Apr 2004 6:04 PM
Environment: Resin 3.x
Description:
SRS box reverts to previous saved/loaded number after a new SRS number has been entered and the Bonding Box button is clicked.
Reprojection/bounding box does not appear to work properly:
If Max Lat. number is changed, and the FeatureType submitted but NOT saved- opening it again in FeatureType Editor shows the new Max Lat number moved to the Min Long box and the Max Lat has reverted to original number it had before editing started the first time.
If Min Long number is changed and saved, etc, when FeatureType is opened in Editor- the number has moved to Min Lat box and Min Long box number has a different number in it.
Max Long overwritten by Max Lat number if the Submit button is pressed. and the feature type opened again in the editor
Pati
JIRA INFORMATION:
If you want more information on JIRA, or have a bug to report see:
