[Geoserver-devel] Jira Tickets
Hi List,
Is it possible to allow a ticket creator on Jira to edit the attributes of a ticket where they’re the reporter? This is fairly common in most ticketing systems but JIRA doesn’t seem to let me do it.
I’d like to be able to update my tickets to new categorisation, “priority” (typically down) and “affected version” where applicable but can’t do so.
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
On Wed, Jan 30, 2013 at 3:00 PM, Jonathan Moules <jonathanmoules@anonymised.com…3638…> wrote:
Hi List,
As far as I know to do that you’d have to be recognized by Jira as a developer, e.g., someone that the issues can be assigned to
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
I asked on the JIRA community forum as to whether it was possible and the response was:
You modify the permission scheme to add Reporter under Edit permissions.
So apparently it is possible.
I think it’d be worth doing; it’d allow the more active reporters to edit their tickets and ensure they’re up-to-date, helping remove some of that particular onus from the devs.
On 30 January 2013 14:05, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Wed, Jan 30, 2013 at 3:00 PM, Jonathan Moules <jonathanmoules@anonymised.com> wrote:
Hi List,
Ing. Andrea Aime
@geowolf
Technical Lead
