[Geoserver-devel] Joining Jira Dev team
We seem to have 148 “easy” tickets in the sprint category and I would say that we should not add any before we can clear a few bugs out of that bucket.
I would recommend this short list for Nadia:
https://osgeo-org.atlassian.net/browse/GEOS-8388
Feels easy, cascading WMTS should not change lower case “access_token” into upper case “ACCESS_TOKEN”. However, it may have some connections into general handling of KVP parameters.
https://osgeo-org.atlassian.net/browse/GEOS-7209
Make importer to take
“crs”: { “type”: “name”, “properties”: { “name”: “urn:ogc:def:crs:OGC:1.3:CRS84” } },
as a synonym to
“crs”: { “type”: “name”, “properties”: { “name”: “urn:ogc:def:crs:EPSG:4326" } },
Feels also easy but perhaps it can lead to deep waters about how to handle different ways for defining CRS and how it affects axis order.
If you can’t resolve those then comments about possible problems in KVP and CRS handling would be valuable as well.
-Jukka Rahkonen-
Lähettäjä: Torben Barsballe [mailto:tbarsballe@…3839…]
Lähetetty: 28. marraskuuta 2017 21:46
Vastaanottaja: Nadia Copeland <ncopeland@…3839…>
Kopio: geoserver-devel geoserver-devel@lists.sourceforge.net
Aihe: Re: [Geoserver-devel] Joining Jira Dev team
(attachments)
Hello Nadia,
Welcome! The first thing to do would be to get a GeoServer development environment set up, see the Developer Guide. You’ll also want to familiarize yourself with the Project Procedures.
Bug Stomps happen the last Friday of each month; the next one is December 29 (which I expect will be sparsely attended due to the holidays). That said, you are welcome to contribute fixes whenever. The list of “simple” bugs that we use for the Bug Stomp is here, it is usually a good starting point: https://osgeo-org.atlassian.net/issues/?filter=11300
Torben
On Tue, Nov 28, 2017 at 11:18 AM, Nadia Copeland <ncopeland@…3839…> wrote:
Hello!
I have just subscribed to the newsletter and am interested in taking part in the bug stomps as recommended by a colleague.
I am studying to be a geospatial developer and have joined Boundless as a corporate concierge until I graduate and will move into a gis developer apprenticeship. Getting involved in the geo community and improving my skills through volunteer work and bug fixes is awesome to me! I am proficient in C# and Java and am learning Javascipt syntax.
Thank you and look forward to participating!
Best,
Nadia
Nadia Copeland
Corporate Concierge | Boundless
ncopeland@boundlessgeo.com
314.596.6171 (cell)
@boundlessgeo
BoundlessLogo
Geoserver-devel mailing list
On Wed, Nov 29, 2017 at 4:56 PM, Rahkonen Jukka (MML) <
"crs": { "type": "name", "properties": { "name": "urn:ogc:def:crs:OGC:1.3:CRS84"
as a synonym to
That's indeed a case where OGC defined the first as lon/lat and the second
as lat/lon.
But maybe within the context of GeoJSON that difference can be ignored.
From the GeoJSON spec we implement (the older one, the new one is a bit
retarded and has not notion of CRS at all....):
A position is represented by an array of numbers. There must be at least
two elements, and may be more. The order of elements must follow x, y, z
order (easting, northing, altitude for coordinates in a projected
coordinate reference system, or longitude, latitude, altitude for
coordinates in a geographic coordinate reference system). Any number of
additional elements are allowed – interpretation and meaning of additional
elements is beyond the scope of this specification.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
