[Geoserver-devel] Joining the Developer list
I am a M.E. of National Taiwan Ocean University and become a new developer for geoserver-devel and want to contribute myself to this project.
I have built up the geoserver environment. Next, I will learn something from community and hope to coorporate to do something.
Best Regards,
KuanYu
Hi KuanYo,
welcome to the list.
Are you looking for something to do in a particular area?
If you are not familiar with GeoTools I would learn about it first, as GeoServer is built on top of it, see:
http://docs.geotools.org/
If instead you’re already familiar and looking for something to do, I guess you can just go in the bug tracker,
there is a list of issues that we believe are quicker to fix than most others here:
https://osgeo-org.atlassian.net/issues/?filter=11300
Hope this helps
On Wed, Nov 29, 2017 at 7:36 AM, 沈冠宇 <sos84418@anonymised.com> wrote:
Best Regards,
KuanYu
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Andrea Aime
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Hi Andrea,
Thanks for guiding me for right path.
I have used geotools and geoserver to build small project so I thing the basic environment
and knowledge is Ok…but I will be continuing in-depth research them.
I am a newbie in the bug tracker. If I will charge issue, I just leave a comment on it?
Best,
KuanYu
comment on it?
Maybe write a comment here on the list
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Andrea,
Ok!
Which one you recommend to do first between geotool and geoserver?
Thank you for all your help.
Best Regards,
KuanYu
2017年11月29日 下午11:43,“Andrea Aime” <andrea.aime@anonymised.com>寫道:
Ing. Andrea Aime
@geowolf
Technical Lead
I would recommend to start with GeoTools, it is generally simpler.
On Thu, Nov 30, 2017 at 1:28 AM, 沈冠宇 <sos84418@anonymised.com> wrote:
Hi Andrea,
Ok!
Best Regards,
KuanYu
Ing. Andrea Aime
@geowolf
Technical Lead
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
