[Geoserver-devel] JSON Nesting too deep exception due to hard-coded limit
Hi community.
I’m reproducing an exception using Complex Features and WFS GeoJSONBuilder on Geoserver 2.16 (master) with this stack trace:
net.sf.json.JSONException: Nesting too deep.
at net.sf.json.util.JSONBuilder.push(JSONBuilder.java:270)
at net.sf.json.util.JSONBuilder.object(JSONBuilder.java:240)
at org.geoserver.wfs.json.ComplexGeoJsonWriter.encodeFeature(ComplexGeoJsonWriter.java:105)
at org.geoserver.wfs.json.ComplexGeoJsonWriter.encodeComplexAttribute(ComplexGeoJsonWriter.java:563)
at org.geoserver.wfs.json.ComplexGeoJsonWriter.encodeProperty(ComplexGeoJsonWriter.java:409)
at org.geoserver.wfs.json.ComplexGeoJsonWriter.encodeProperty(ComplexGeoJsonWriter.java:383)
at java.util.ArrayList.forEach(ArrayList.java:1257)
This exception is not present on previous versions (2.14 for example) and looks like we are facing it since now some extra “properties” attributes were added to GeoJSON encoding recently.
Checking for the root problem seems like json-lib JSONBuilder class has a hard-coded limit of 20 nested levels as we can see on:
https://github.com/aalmiray/Json-lib/blob/master/src/main/java/net/sf/json/util/JSONBuilder.java#L61
Since we added new levels to GeoJSON encoding it is a good idea to relax a bit this limit, but as you can see the problem is this limit is not configurable since the static variable is final. So I see two solutions to this:
  • Fork json-lib and relax limit or make it configurable.
  • Use reflection for modify the value at runtime.
    Of course the first solution sounds better since reflection can be problematic for some environments (for example blocked by a security manager).
I currently did a fork relaxing the limit to 5000 in:
https://github.com/fernandor777/Json-lib/tree/limit-fix-2.4
So it could be good to discuss the best approach to fix this and, of course, to read better ideas from all you.
Thanks.
Fernando Mino
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Fernando Mino
Software Engineer
Via di Montramito 3/A
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Hi community.
Bit of context, in 2.16.x full features are always encoded as GeoJSON features, no matter where in the containment hierachy, that preserves their identity and
makes them recognizeable as features. Before they were plain json object without type or identity.
However, if one has a model in which everything is an identifiable feature, it’s adding an extra level of “properties” per object.
We could also discuss having a flag in the WFS configuration on whether to preserve nature and identity of nested features (and/or a request parameter, I believe
there is already a map of “format options” in WFS, but not 100% sure).
Third option we cannot afford in the short term: rewrite the json encoder using another library (jackson?). And yep, it’s a lot of work, hence the “cannot afford”.
Running inside a security manager is uncommon, but not unheard of… the intersection of complex json users with deeply nested models and
users running inside a security manager might as well be empty, but I’d be more comfortable having our own fork of jettison, considering tha
the library is basically dead anyways (there is a semi-dormant version at https://github.com/jettison-json/jettison still limiting encoding to 20, but I believe there were backwards compat issues, Torben, is it jettison or am I confusing it with another library?)
we have forked other libraries for similar reasons.
We should probably schedule a sprint in the future to cleanup our json/geojson management situation, since now both OGC batch of services and practical usage are
agreeing on favoring JSON over XML.
A fixed limit is still fixed… I’d recommend making it at least tunable with a system variable, e.g.
maxFeatures = Integer.parseInt(System.getProperty(“json.maxFeatures”, 5000)
Also, 5000 seems like a large limit, I’m guessing it would allow 5000 by 5000 objects in memory before encoding, that
seems a too big of a number. How about defaulting to 100?
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
please see my replies bellow:
Hi community.
Well, is true that preserving the nature and identity of nested features comes with the cost of extra properties.
This may be a problem when accessing the GeoJSON properties in a pure JSON way, i.e. no GeoJSON specific parisng support, no interest in semantics of the features.
So +1 for the optionality of preserving the complex features entity, but I would say that by default the nature and identity of nested features should be preserved.
+1 for the mid-term approach of forking the library and making the limite configurable.
+1 for a default value of 100, and throwing an exception fit hat limit is reached (like I think ti is the case already).
Geoserver-devel mailing list
[Geoserver-devel@anonymised.comsts.sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-devel](https://lists.sourceforge.net/lists/listinfo/geoserver-devel)
<details class='elided'>
<summary title='Show trimmed content'>&#183;&#183;&#183;</summary>
GeoServer Professional Services from the experts! Visit [http://goo.gl/it488V](http://goo.gl/it488V) for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 [http://www.geo-solutions.it](http://www.geo-solutions.it) [http://twitter.com/geosolutions_it](http://twitter.com/geosolutions_it) ------------------------------------------------------- *Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.*
</details>
Just to clarify bellow:
Hi community.
Where I mean +1 for: GeoJSON features by default, with an option to disable (i.e. remove the extra nested properties inside properties inside properties).
Nuno Oliveira
experts!
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
</details>
In this case the nesting hard-coded limit is present on JSON-lib library:
But, of course, if jettison is present on others encoding processes it could be needed to fork it too since it has nesting hard-coded limit in the same way (and same value).
so summarizing the discussed issues, the plan could be:
  • Regarding the JSON library number of nested objects limit:
  • Fork the JSON library and make the limit configurable, by default 100 is recommended
  • Where should the fork be created? in GeoServer [1]
  • Plan a code sprint to clean the JSON libraries use by GeoServer, JSON is becoming quite relevant
  • Regarding the nested encoded properties format (used to preserve complex features semantics):
  • Use the current format as default, i.e. we preserver the complex features semantics
  • But allow an administrator to disable it globally or per workspace
Does this makes sense?
Best regards,
Nuno Oliveira
[1] https://github.com/geoserver
