Having an issue with the JSON output format and date/time formatting.
What I've gathered from the internet (?) is that JSON doesn't
prescribe a formatting for date/time objects up until May 26 2011 [1],
and now recommends date/times to be formatted as ISO 8601 dates
<http://www.w3.org/TR/NOTE-datetime>
Customer is requiring date/times to be formatted as per as ISO 8601
Fix would be easy:
--- a/wfs/src/main/java/org/geoserver/wfs/response/GeoJSONBuilder.java
+++ b/wfs/src/main/java/org/geoserver/wfs/response/GeoJSONBuilder.java
@@ -250,4 +251,14 @@ public class GeoJSONBuilder extends JSONBuilder {
"Unable to determine geometry type " + geometry.getClass());
+ @Override
+ public GeoJSONBuilder value(Object value){
+ if(value instanceof java.util.Date){
+ value = Converters.convert(value, String.class);
+ super.value(value);
+ return this;
Any objection?
[1] <http://tools.ietf.org/html/draft-zyp-json-schema-03#section-5.23>
Gabriel Roldan
OpenGeo - http://opengeo.org
