On Wed, Aug 1, 2012 at 12:27 PM, Andrea Aime
<andrea.aime@anonymised.com> wrote:
On Wed, Aug 1, 2012 at 4:40 PM, carlo cancellieri <ccancellieri@anonymised.com>
wrote:
my name is Carlo Cancellieri and I'm working for GeoSolutions S.A.S. on
GeoServer to add some response and exceptions handlers to get responses and
exceptions in json and jsonp format.
Here is the list of provided Improvements (some of the following are
produced by Andrea A. or Simone G.):
- Adding JsonP output format to the WFS Describe
- Adding JsonP output format to WMS GetFeatureInfo
[Ongoing]
- Add Json[P] support to WMS DescribeLayer [missing tests]
- Adding JsonP support to WMSServiceExceptionHandler [todo]
The target branch is 2.2.x.
Is it possible to merge those improvements into geoserver?
Do you need some more info?
Carlo, most of the changes are purely additive and small, the question for
those is whether
they can land directly on 2.2.x. Given the interest on json and jsonp I
guess
that would be a good idea for 2.2.1, but you should explain how the requests
are going to work,
make some example of the requests (params) and how the outputs will look
like.
Carlo, looks like a straight forward patch. I personally have no
objection for it to land on the 2.2.x branch. Agree with Andrea in
that a couple sample requests and some doc would be in place though.
You should explain the changes for DescribeLayer, which now handles only
one output format and after will have two, with two new Response objects
making
the output format actually pluggable: this one is a API change, needs some
explanation
of how the API will look like
After a cursory look at the patch, I don't think it even qualifies as
an API change. The only "API change" I can see is the change in the
return type of the WebMapService.describeLayer operation:
<https://github.com/ccancellieri/geoserver/commit/2a9709b219e1c730d85fb467747e5de2a57f159b#L4L47>
But DefaultWebMapService was already narrowing the return type. The
API and workflow is the same, imposed by the Dispatcher framework, so
any Response found on the app context that can handle whatever it is
that the operation returns will work. That is to say, I don't think
the changes deserve much explanation, at least I'm missing something
obvious, which can well be as I made just a cursory look at the patch.
Gabriel
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
mob: +39 339 8844549
Live Security Virtual Conference
Exclusive live event will cover all the ways today's security and
threat landscape has changed and how IT managers can respond. Discussions
will include endpoint security, mobile security and the latest in malware
threats. http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
Geoserver-devel mailing list
Gabriel Roldan
OpenGeo - http://opengeo.org
