Please see GeoTools proposal for details:
The GeoServer details are here:
A formal PR is pending fixing a borehole test failure.
Jody Garnett
Jody Garnett
Upgraded completed on geoserver master, … and we have some trouble with community modules.
Will report back shortly.
Jody Garnett
The following community modules are temporarily removed from the build:
Jody Garnett
For GeoFence, I have two branches which might help folks move forward:
For Hibernate-spatial, I have a fork and a branch here: https://github.com/jnh5y/hibernate-spatial1/tree/jts-1.15.1
From what I can gather, GeoFence uses this for H2 and Oracle Hibernate support.
A branch for GeoFence is here: https://github.com/jnh5y/geofence/tree/jts-1.15.1. There seem to be some dependencies which should likely be upgrade to the later version of GeoTools.
I’m happy to try and help with those branches, but I think I’m at the edge of knowledge…
Jim
- geogig
- script
- geofence
- geofence-server
Jody GarnettOn Fri, 29 Jun 2018 at 14:10, Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody GarnettOn Tue, 26 Jun 2018 at 13:09, Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett------------------------------------------------------------------------------ Check out the vibrant tech community on one of the world's most engaging tech sites, Slashdot.org! [http://sdm.link/slashdot](http://sdm.link/slashdot)
_______________________________________________ Geoserver-devel mailing list [Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net) [https://lists.sourceforge.net/lists/listinfo/geoserver-devel](https://lists.sourceforge.net/lists/listinfo/geoserver-devel)
Dear all,
I’m taking care of fixing the GeoFence and GeoFence Server dependencies.
@Jim Hughes, many thanks for the branches, I will have a look at them and backport changes. I will contact you again in case I need clarifications.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
mob: +39 331 6233686
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
