I've made a comparison between the approaches one can take to
have a one time setup/teardown in order to avoid going thru
the initialization of geoserver over and over and over
during tests (at least for read only ones).
The extra requirement is that the one time setup has
to allow calling non static methods, since in GeoServetTestSupport
we have 3 template methods that subclasses can alter
in order to drive how the setup is done.
This project:
http://www.nabble.com/file/p16609696/onetimesetup.zip onetimesetup.zip
shows how one time setup/teardown
can be achieved using the three testing frameworks.
The first results is that junit4 and junit3 tests can
coexist in the same project, but testng not. Once
you add testng to the classpath, surefire will use only
that one to run the tests, and a class cast exception
occurrs trying to run the junit3 tests (probably due
to the suite() method, not sure).
Anyways, besides this, here is a rough summary.
JUnit3
The base class, OneTimeSetupJunit3, sets the scene
for one time setup. Class extending it can specify
the following methods:
public void oneTimeSetUp()
public void oneTimeTearDown()
protected void setUpInternal()
protected void tearDownInternal()
If only those are specified, the order of execution
*for each test method* is:
oneTimeSetup
setUpInternal
tearDownInternal
oneTimeTearDown
(that is, the one time methods, if present, behave
like normal setup/teardown would).
If the following method is added:
public static Test suite() {
return new OneTimeTestSetup(new OneTimeJunit3Test());
then the one time setup and tear down methods are run
only before running all tests, and after running them
(so they become true one time setup/teardown).
All fine? No. When you add that suite() method,
Eclipse will run all the tests even if you ask it
to run just once. So if you need to debug just one
method, that suite() method has to be commented
out, and uncommented before committing. How inconvinient.
Junit4
The base class, OneTimeSetupJunit4, tries to allow
for the same approach as the OneTimeSetupJunit4.
Unfortunately I could not manage to allow for
an ovveridable OneTimeTearDown.
Yet, for our specific case, it's not really needed,
since all template methods we need to call are
in the setup phase, so we could get away marking
the only one OneTimeTearDown method we need
as @AfterClass
TestNG
Look ma, no base class. The annotations here are placed
on standard non static methods, so no machinery
is really needed.
To run the TestNG tests in Eclipse a plugin is
needed, that you can download from here:
http://testng.org/doc/download.html
My take
Hum, the junit3 approach is a little annyoing but
works, and does not require us to learn anything new.
The TestNG one is the one that looks better thought,
no need to fight against the framework.
So, what shall we do? Blue pill, junit3, red pill,
juni4, green pill, TestNG.
What are you going to swallow?
Please vote
View this message in context: http://www.nabble.com/JUnit3%2C-JUnit4-and-TestNG-comparison-(for-one-time-setup)JUnit3%2C-JUnit4-and-TestNG-comparison-(for-one-time-setup)-tp16609696p16609696.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
