Recently new directories have been added to the data directory structure. As we add new directories would we be able to keep naming consistent. And what i mean by consistent is use of underscore notation vs camel back notation. Currently I think the only use of underscore notation has been for the "user_projections" directory.
Not a big issue by any means but i think we should try to be conistent in naming. It came to mind as I see that another directory "loggingConfigs" has been added to support user logging configuration files. On this note any objection to just "logging" :). Dropping the "Configs" part as no other directories use "Configs" as a prefix, but are indeed for configuration.
Apologies if this email comes across as anal.
-Justin
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
Sounds good to me. I agree with dropping the 'Configs' from the directory name.
So there are two hings in logging: configs and the actual logs. I feel like these two things should be stored in different directories, but I could be convinced that they could go in some different sub-directory-type-structure.
How about:
data_dir/logs/LOGFILES GO HERE
data_dir/logs/profiles/CONFIG_FILES_GO_HERE
Would this be confusing to have the 'logs' directory also hold the logging profiles?
--saul
From: geoserver-devel-bounces@lists.sourceforge.net on behalf of Justin Deoliveira
Sent: Wed 7/11/2007 3:07 PM
To: 'geoserver-devel@lists.sourceforge.net'
Subject: [Geoserver-devel] keeping data directory structure naming consistent
-Justin
Justin Deoliveira
http://topp.openplans.org/>
This SF.net email is sponsored by DB2 Express
Download DB2 Express C - the FREE version of DB2 express and take
control of your XML. No limits. Just data. Click to get it now.
http://sourceforge.net/powerbar/db2/
Geoserver-devel mailing list
I'd prefer to have the logs directory also hold logging profiles. Just put 'profile' in the name of the profile files. I don't really like lots of directories in the data directory.
Chris
How about:
--saul
-Justin
Justin Deoliveira
!DSPAM:4005,46953a6647833362379201!
I second this.
Chris
How about:
--saul
-Justin
Justin Deoliveira
!DSPAM:4007,46953b1b48721030819293!
Justin Deoliveira
