here is a topic for today’s PSC meeting (not feeling all that well, might not make it to the meeting).
In GeoSolutions we found that we need to run custom builds of the 2.18.x series, mostly because of its relationship with GeoNode. GeoNode tends to stay a little behind in terms of GeoServer version, e.g., the latest release uses 2.19.x, but the release before is still quite commonly installed. In addition, they don’t typically use public releases, but snapshots with the exact set of fixes and improvements they need.
I was wondering, would it be possible to keep the old maintenance series builds going for another six months, after we stop making releases?
I don’t think the extra CPU usage would be unreasonable, and the storage would be the same,
if you check, we still have 2.16.x nightlies on the build server:
https://build.geoserver.org/geoserver/
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 333 8128928
