following http://jira.codehaus.org/browse/GEOS-3185
I would like to draw a plan to revert back KML to refresh
mode and have people ask explicitly that they do want superoverlays.
The first step would be to have the kml reflector to default
to refresh mode as opposed to super-overlay mode (and adjust
the tests accordingly).
The second would be to make the superoverlay mode visible anyways,
somehow. On 1.7.x I guess we can add it as a further link in the
preview?
http://geo.openplans.org:8080/geoserver/mapPreview.do
Imagine a "KML (superovelay)" link among the others. There's
enough space to just add it no?
Things are different on trunk, the preview page looks like
attached and it's already quite busy.
I would like to add the superoverlay into the the "all formats"
drop down box as KML (superoverlay), however,
this requires the superoverlay to be turned into a valid WMS
output format, as the list is populated by scanning the map producers.
I guess it's doable if we create a subclass of KMLMapProducer that
does use the mime type:
application/vnd.google-earth.kml+xml; mode=superoverlay
(longest mime ever) and that forces is the superoverlay mode.
Otherwise I can decouple somehow the map producers and the
drop down UI generation, with every producer having one or
more descriptor bean that can be used to build a UI entry.
Opinions?
Andrea Aime
OpenGeo - http://opengeo.org
(attachments)
