I was interested in getting feedback to see if this was something others would find valuable.
More user friendly layer name/description in Google Earth. Layer titles and abstract are displayed as opposed to just the basic “workspace:name” for the network link names previously. Fallbacks are provided to ensure if any of this data is missing layers are not broken.
New format option parameter “kmlrefresh” can be used to specify either a set interval in seconds or “expires” to utilize the cache expiration value specified in layer config. This will cause layers to automatically be refreshed without pan/zom when using kml refresh mode - useful for big-screen displays that must be regularly updated.
New format option parameter “kmlvisible” can be used to set the initial state of all network links to be on or off. Useful if multiple layers are enabled and due to data volume it is desirable to not immediately request all layer data.
These are improvements I implemented into a custom build of GeoServer to support a client and thought they may be of value to the community. All unit tests and documentation have been updated to cover these changes.
Documentation added at the bottom of format options WMS section:
Sounds like a neat bit of work Jonathan. Impressed that you have both documentation and unit tests.
Can you write up a quick proposal for the work? We are getting close to the code freeze.
I usually recommend writing a proposal prior to customer sign off. Either before starting work (to help confirm the design direction and minimize risk). You have already hit the usual gaps (documentation unit tests). A proposal is still useful to ensure our format options are consistent and to help schedule round release.
In the best case scenario this can identify potential collaborators (either developers to share workload, or users to donate QA testing).
Jonathan Meyer | Senior Software Engineer
Applied Information Sciences
Dive into the World of Parallel Programming! The Go Parallel Website,
sponsored by Intel and developed in partnership with Slashdot Media, is your
hub for all things parallel software development, from weekly thought
leadership blogs to news, videos, case studies, tutorials and more. Take a
look and join the conversation now. http://goparallel.sourceforge.net
Jody
Jonathan Meyer
Jody
Swell. Thanks for the direction. I added a proposal for both the pull request discussed here and the other pull request I put in for relative time.
I did not attempt to add anything to the main proposal page as I assumed you or someone else added items there once it was determined what stage of the process they were in.
One other note of clarification, I proposed this for the next major release (2.7), but if there is allowance for inclusion into a sooner release (2.5/2.6?) that would be great. I assume that is somewhat dependent on the understood side-effects of the change.
Jody
