If you need a quick fix for the swapped coordinates, this might help:
diff --git a/src/kml/src/main/java/org/geoserver/kml/sequence/PlainFolderSequenceFactory.java b/src/kml/src/main/java/org/geoserver/kml/sequence/PlainFolderSequenceFactory.java
index c32e3280e…4a973aac5 100644
— a/src/kml/src/main/java/org/geoserver/kml/sequence/PlainFolderSequenceFactory.java
+++ b/src/kml/src/main/java/org/geoserver/kml/sequence/PlainFolderSequenceFactory.java
@@ -113,8 +113,8 @@ public class PlainFolderSequenceFactory extends AbstractFolderSequenceFactory {
LatLonBox gobox = go.createAndSetLatLonBox();
gobox.setNorth(box.getMaxY());
gobox.setSouth(box.getMinY());
(I’ll make the tests and turn that into a PR at some point after the ticket gets created).
Brad
From: bradh@anonymised.com [mailto:bradh@anonymised.com]
Sent: Monday, 22 January 2018 9:59 PM
To: ‘Idan Miara’ idan@anonymised.com
Cc: ‘Geoserver-devel’ geoserver-devel@lists.sourceforge.net; ‘Andrea Aime’ andrea.aime@anonymised.com
Subject: Re: [Geoserver-devel] KML/KMZ support broken?
I would agree that the LatLonBox values appear to be swapped in the GroundOverlay. This will occur in KML compressed or plain, but maybe not in network link. Can you please file a Jira ticket for that?
The Document/Folder structure is almost certainly valid, and lack of handling is a bug in QGIS (or some supporting library).
Brad
Sent: Monday, 22 January 2018 9:36 PM
To: bradh@anonymised.com
Cc: Andrea Aime <andrea.aime@anonymised.com>; Geoserver-devel <geoserver-devel@lists.sourceforge.net>
Hi Brad & Andrea
Thanks for your kind replys.
I can reproduce the problem with a fresh Geoserver platform independent zip installation (Master or 2.12.1, same results) as follows:
Layer Preview-> nurc:Img_Sample → Select KML (compressed)
unzip nurc-Img_Sample.kmz. you will get wms.kml (attached) and a png raster.
Please note in this KML file:
-130.85168
-62.0054
which is wrong becuse it should be swapped as west should be <east.
As Brad kindly noted, if you open this KML/KMZ in Google Earth Pro it works just fine even tough this error.
I guess it just assumes that west<east and just swaps it internally.
Open this KML in QGIS (2.18.x or Master, same results) you will get a blank square instead of the raster.
fixing wms.kml to load in QGIS:
edit wms.kml as follows:
Remove the following 4 lines:
I’m didn’t read the KML spec, but As Andrea kindly noted, this might be a QGIS limitation.
Save as wms1.kml (attached).
load it with QGIS, you will get the raster but horizontally swapped. I guess QGIS interperate east<west as swapped image, and doesn’t assume that the values should be swapped, I’m not sure which of those error handlings is ‘correct’.
I will report this issue to qgis-devel list.
edit wms1.kml as follows:
swap east-west
-130.85168
-62.0054
Save as wms2.kml (attached).
wms2.kml loads perfectly fine in QGIS.
Note that all 3 files load correctly in Google Earth Pro.
Kind regards,
Idan
On 22 January 2018 at 02:21, <bradh@anonymised.com> wrote:
Hi Idan,
Just to follow up on Andrea’s suggestions, I did some testing with a current GeoServer (master) build and
Google Earth EC 7.3.0.3832 (32-bit) with some rasters from the standard release (nurc:ImgSample and nurc:Pk50095). They looked fine – definitely no reversed images, so its unlikely to be a general problem.
I did try downloading the KML but my QGIS 2.18.15 didn’t recognise it as a raster layer, and drag and drop resulted in empty attribute tables.
Brad
From: Andrea Aime [mailto:andrea.aime@anonymised.com]
Sent: Monday, 22 January 2018 5:13 AM
To: Idan Miara <idan@anonymised.com>
Cc: Geoserver-devel <geoserver-devel@anonymised.comforge.net>
Hi Idan,
are you sure there is a bug in GeoServer and not a limitation in QGIS instead?
The second issue you report is definitely a problem in QGIS, a KML document can have whatever structure it wants, nesting
documents, layers and features as desired, see:
https://developers.google.com/kml/documentation/kmlreference
The issue with order of coordinates is also strange, as KML mandates a specific order (lon/lat) and we never received
a complaint about it. It could be related to your particular TIFF?
Try to reproduce with a demo TIFF layer and let’s see how that works (I wanted to have a look myself but I have no time).
Final note, unless you’re interested in changing the GeoServer code yourself, this is the wrong list, your question
seems more like a GeoServer users list (asking there you’d also have a 4 times larger audience).
On Wed, Jan 17, 2018 at 2:34 PM, Idan Miara <idan@anonymised.com> wrote:
I’m trying to get a KMZ (KML compressed) file from Geoserver (2.12.1) and load it in QGIS (2.18.14).
The input raster is a RGB Tiff.
CRS: WGS84 Lat/Lon
The output KMZ that I get via the Layer preview is broken.
I could fix it and load it successfully in QGIS in the following way if I edit the inner KML:
swap east and west (in the original kml east<west) -
seems like an obvious bug.
I’m not sure why this helps, but it does.
If necessary, I would generate and attach a small Tiff to reproduce this issue (otherwise I would assume it can be reproduced with any Tiff).
Kind Regards,
Idan.
Geoserver-devel mailing list
Andrea Aime
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
