[Geoserver-devel] Last minute 2.7.0 backports
Travis and Jody,
in your capacity as release managers for 2.7.0, I would like your approval, if you think it safe, for some last minute 2.7.0 backports of documentation improvements, WFS 2.0 demo requests, and minor app-schema test pom.xml preening. No code changes:
https://github.com/geoserver/geoserver/pull/967
These non-code changes are optional but should be quite safe. The WFS 2.0 demo requests and filter documentation are in response to discussion on the mailing list (from 2013!):
http://osgeo-org.1560.x6.nabble.com/Creating-Geoserver-Layer-from-custom-WFS-td5076277.html
I would also like to take this opportunity to call for anyone else with last minute backports to make themselves known.
Kind regards,
Ben Caradoc-Davies <ben@anonymised.com>
Software Engineer
Transient Software <http://transient.nz>
New Zealand
Documentation back ports yes!
WFS 2.0 demos request yes (no real danger for client applications - there was also some broken demo requests in the 2.7-RC1 that may need fixing).
test pom.xml preening yes (no real danger for client applications).
There is one pull request from travis (addressing a catalog loading regression) that should make the cut …
… however Andrea had a good idea (to make this a global setting rather than a -D system property - not sure if that works (because if we turn the setting on the existing catalog may not load!).
On 9 March 2015 at 13:39, Ben Caradoc-Davies <ben@anonymised.com> wrote:
Travis and Jody,
Kind regards,
Software Engineer
New Zealand
Jody Garnett
On Mon, Mar 9, 2015 at 10:01 PM, Jody Garnett <jody.garnett@anonymised.com>
regression) that should make the cut ...
.. however Andrea had a good idea (to make this a global setting rather
Same will happen if you set the sysvar that enables the checks... it's
easier for the admin to find (which its pros and cons), and would allow us
to lock down
the data dir by default in the release data dir for newer installations,
while preserving backwards compat for older ones.
The sysvar instead would have to be stay disabled forever to preserve
backwards compat, so we would end up locking the file names only if the
admin explicitly set the sysvar.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Jody, which requests were broken? I was only aware of OL3 preview problems.
The only demo request problems I encountered were caused by my browser configuration and were fixed by disabling NoScript application boundary enforcer.
Kind regards,
Software Engineer
New Zealand
At least WFS_transactionInsert.xml and WFS_transactionUpdateGeometry use metric coordinates in geometries even the srsName is EPSG:4326. There are also some requests which do work with Geoserver but they are not valid according to standards. Like WFS_getFeatureBBOX.url which is missing mandatory &SERVICE=WFS:
http://localhost:8080/geoserver/wfs?request=GetFeature&version=1.1.0&typeName=topp:states&propertyName=STATE_NAME,PERSONS&BBOX=-75.102613,40.212597,-72.361859,41.512517,EPSG:4326
-Jukka Rahkonen-
________________________________________
enforcer.
Kind regards,
Software Engineer
New Zealand
Dive into the World of Parallel Programming The Go Parallel Website, sponsored
by Intel and developed in partnership with Slashdot Media, is your hub for all
things parallel software development, from weekly thought leadership blogs to
news, videos, case studies, tutorials and more. Take a look and join the
conversation now. http://goparallel.sourceforge.net/
Geoserver-devel mailing list
Jukka,
while we are on the topic of missing parameters, not one demo URL request contains a NAMESPACE (WFS 1.1.0) or NAMESPACES (WFS 2.0.0) parameter to define the namespace prefixes used for feature types and property names. GeoServer is by default quite permissive in this regard; it is happy to guess that an undefined prefix matches a workspace of the same name. However, XML namespace prefixes are always local to an instance document, and never have meaning across services. I do not think that deegree will accept these requests.
Kind regards,
Ben.
On 10/03/15 11:46, Rahkonen Jukka (MML) wrote:
-Jukka Rahkonen-
enforcer.
Kind regards,
Software Engineer
New Zealand
Software Engineer
New Zealand
Jukka,
I checked and the values supplied in these demo requests are faithfully inserted into the data set, honouring the supplied CRS. I can also confirm that the numbers are bogus, misleading, and look like eastings and northings; they should be changed.
Kind regards,
Ben.
Software Engineer
New Zealand
I take that back. Even before the transactions, there is something weird going on: all the coordinates are in three dimensions. WFS 1.1 and 2.0 requests confirm that this is a 3D CRS (tested on master):
Each point has 3 coordinates, with latitude duplicated as z:
http://localhost:8080/geoserver/wfs?service=WFS&version=1.0.0&request=GetFeature&typename=topp:tasmania_roads
srsDimension="3", and latitude is duplicated as z (WFS 1.1):
http://localhost:8080/geoserver/wfs?service=WFS&version=1.1.0&request=GetFeature&typename=topp:tasmania_roads
srsDimension="3", and latitude is duplicated as z (WFS 2.0):
http://localhost:8080/geoserver/wfs?service=WFS&version=2.0.0&request=GetFeature&typenames=topp:tasmania_roads
Can anyone please explain why this might be the case? I do not see anything unusual in the layer settings. I will not fix the values until I understand whether this is a bug,
Kind regards,
Software Engineer
New Zealand
-----Original Message-----
Sent: 09 March 2015 23:25
To: Rahkonen Jukka (MML); Jody Garnett
Cc: geoserver-devel@lists.sourceforge.net
Subject: Re: [Geoserver-devel] Last minute 2.7.0 backports
Jukka,
The correct namespaces WFS 2.0.0 KVP Get requests will not currently work (https://jira.codehaus.org/browse/GEOS-6885) so you can't put that as a demo request yet.
Marcus Sen
British Geological Survey
Keyworth
Nottingham
NG12 5GG
Web: http://www.bgs.ac.uk
This message (and any attachments) is for the recipient only. NERC is subject to the Freedom of Information Act 2000 and the contents of this email and any reply you make may be disclosed by NERC unless it is exempt from release under the Act. Any material supplied to NERC may be stored in an electronic records management system.
