[Geoserver-devel] "Latest" documentation not updating (or showing outdated pages?)
it seems the latest published docs are not synched with the sources, for example, this
page has been modified and split with two sub-pages that are not visible:
http://docs.geoserver.org/latest/en/user/community/wps-download/index.html
See the sources:
https://github.com/geoserver/geoserver/tree/master/doc/en/user/source/community/wps-download
Looks like the build responsible for publishing docs has been run on Dec 20th (so after the
changes to the pages above) but unsure why nothing new is showing up:
https://build.geoserver.org/view/geoserver/job/geoserver-master-live-docs/
Ideas?
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Looking into this, I’ve found the issue:
From my notes/email on the 2.12-RC1 release:
Now that everything on ares has been disabled (as of early December), the jobs which were publishing to docs.geoserver.org are no longer running.
Seems like the up-to-date docs are available from https://build.geoserver.org/geoserver/master/doc/en/user/
Not a long-term solution by any stretch of the imagination, but at least they are available somewhere.
Possible solutions:
  1. Modify docs.geoserver.org to support https, so it is able to proxy the docs on the build server
  2. Migrate docs.geoserver.org to a more modern architecture.
    Unfortunately, neither of these are trivial, and I don’t know of a good interim solution.
Torben
On Mon, Jan 8, 2018 at 9:21 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
See the sources:
Ideas?
Ing. Andrea Aime
@geowolf
Technical Lead
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
On Mon, Jan 8, 2018 at 6:45 PM, Torben Barsballe <
tbarsballe@anonymised.com> wrote:
Possible solutions:
3. sftp-ing the results of the build to docs? I guess it needs a auth
certificate installed on build though
Ing. Andrea Aime
@geowolf
Technical Lead
I think that might end up running into some of the the same problems as 1, but might be a viable workaround.
I’ll see if someone at Boundless who manages those machines can set up the proper cert.
Torben
On Mon, Jan 8, 2018 at 9:53 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Mon, Jan 8, 2018 at 6:45 PM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Possible solutions:
  1. sftp-ing the results of the build to docs? I guess it needs a auth certificate installed on build though
Ing. Andrea Aime
@geowolf
Technical Lead
3 wound up being a viable option, docs should be up-to-date now.
I’ve updated the stable/mantain/latest doc builds with the requisite scp commands, and everything seems to be working.
Torben
On Mon, Jan 8, 2018 at 9:58 AM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Torben
Possible solutions:
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Torben,
yep, that seems to have done the trick, thanks a lot!
On Tue, Jan 9, 2018 at 10:19 PM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Torben
Torben
Possible solutions:
Ing. Andrea Aime
@geowolf
Technical Lead
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
You’re welcome.
There might still be some weirdness here or there, I had to do a few finnicky things to get the swagger API docs working, but everything should be functional.
Torben
On Wed, Jan 10, 2018 at 6:26 AM, Andrea Aime <andrea.aime@anonymised.com268…> wrote:
Hi Torben,
On Tue, Jan 9, 2018 at 10:19 PM, Torben Barsballe <tbarsballe@anonymised.com3839…> wrote:
Torben
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
Torben
On Mon, Jan 8, 2018 at 6:45 PM, Torben Barsballe <tbarsballe@…3839…> wrote:
Possible solutions:
Ing. Andrea Aime
@geowolf
Technical Lead
