On Mon, Feb 26, 2018 at 9:57 AM, Alessio Fabiani <alessio.fabiani@anonymised.com> wrote:
So,
further investigation on this highlighted that the issue was due to a configuration issue (let’s say so).
Basically with the GeoFence plugin installed and applying a “DENY” all rule if no other matches, instead of the default “ALLOW” all, makes this feature not working correctly.
The main problem is that the OWS Disapatcher either does not recognize the WMS service or invokes the “getAccessLimits” on the requested Feature too early.
In both cases the result is that GeofenceAccessManager is invoked by passing the ResourceInfo only in order to check if the current user has access to it
https://github.com/geoserver/geoserver/blob/master/src/community/geofence/src/main/java/org/geoserver/geofence/GeofenceAccessManager.java#L295
The problem is that the GeoFence Rules Filters are usually much more complex than this, requiring also the OWS Service type and the Request type.
Curiously GeoFence tried somehow to retrieve such missing info from the ThreadLocal
https://github.com/geoserver/geoserver/blob/master/src/community/geofence/src/main/java/org/geoserver/geofence/GeofenceAccessManager.java#L315
but with no success since, at this time, the OWSRequest seems to be not yet stored on it ( Dispatcher.REQUEST.get() returns null ).
The feeling is that maybe the GeoFence plugin is missing some passage here, but on the other side it is hard to figure out how to retrieve missing infos from GeoServer without somehow modifying the core workflow.
For the time being I just make sure that on GeoFence, for resources the user/group has read access, it is present also a rule matching the “DEFAULT” service (which means no-service specified).
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
Via di Montramito 3/A
mob: +39 331 6233686
2018-02-24 14:39 GMT+01:00 Andrea Aime <andrea.aime@anonymised.com>:
On Sat, Feb 24, 2018 at 9:49 AM, Alessio Fabiani <alessio.fabiani@anonymised.com.it> wrote:
Dear all,
I noticed that on recents GS 2.12+ updates the GetCapabilities for single layers work a bit differently from the past:
- the fully qualified layer name is no more recognized, so it is not possible anymore to write something like
http://localhost:8080/geoserver/geosolutions/geosolutions:flares_noaa/wms?request=GetCapabilities
I never knew this was possible, it’s sort of “doubly qualified” that way. Don’t think it made sense, probably worked
by accident.
- the operation now works only if authenticated. It is no more possible to fetch layer capabilities as anonymous
This sounds like a bug, but it’s likely something specific to your installation, these works for example (without authentication):
http://cloudsdi.geo-solutions.it/geoserver/eumetsat/MET10_RGBAirmass_PlateCarree/ows?service=wms&version=1.3.0&request=GetCapabilities
http://cloudsdi.geo-solutions.it/geoserver/eumetsat/MET10_RGBAirmass_PlateCarree/wms?request=GetCapabilities
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
