[Geoserver-devel] Layer group in workspace referencing other workspaces
Hello,
I read in org.geoserver.catalog.impl.CatalogImpl that a check is done to assert that a layer group having a workspace doesn’t references layers or styles sitting in another workspace.
Otherwise GeoServer throws an error like:
java.lang.IllegalArgumentException: Layer group within a workspace (workspaceA) can not contain resources from other workspace: workspaceB
What is the reason behind this check? Does it have to do with some security / access control?
I find this limitation quite problematic and I was wondering how we could improve that.
What about adding an (global? per layergroup?) option where this check would be skipped altogether?
Or maybe things are not simple and that would break something else in GeoServer?
Damiano Albani
Geodan
On Fri, Sep 2, 2016 at 11:59 AM, Damiano Albani <damiano.albani@anonymised.com>
GeoServer?
It would make workspace specific services stop working, only the global
ones could operate (the ws specific one filter the catalog to only make
what's in the current workspace available).
However, only global services can be turned off, the ws specific ones
cannot.
If you want to refer to other workspaces, the layer group should be global,
changing that might prove to be difficult (or could make the code quite
complicated).... not saying it
cannot be done, but it certainly requires more investigation
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
