Hello,
I’m having trouble previewing layers in GeoServer 2.7.1.
It did not exist in 2.4.2.
It occurs when previewing layers with special characters in its name.
Probably related to https://osgeo-org.atlassian.net/browse/GEOS-4858
It did not work to change the document encoding of the OpenLayers3MapTemplate.ftl to UTF-8.
The output format tries to return the response in UTF-8:
OpenLayersMapOutputFormat.produceMap:
template.setOutputEncoding(“UTF-8”);
ByteArrayOutputStream buff = new ByteArrayOutputStream();
template.process(map, new OutputStreamWriter(buff, Charset.forName(“UTF-8”)));
RawMap result = new RawMap(mapContent, buff, MIME_TYPE);
return result;
But, when looking at the response in Chrome I get a content type without charset information:
Content-Type:text/html; subtype=openlayers
The following resources ol3.js and ol.css are correctly served as
Content-Type:application/x-javascript; charset=UTF-8 and
Content-Type:text/css; charset=UTF-8
When looking at the response from the GetMap response and copying the content to a text editor I can see that the encoding of the document is “UTF-8 without BOM”.
If I serve the same file locally (through IIS as plain html) I get the same behavior but when saving the document as UTF-8 I get a working layer preview page.
Any ideas on how to get the RawMap result to render the charset=UTF-8 information to the browser?
Olle Markljung
Hi again,
Adding
to the of the ol3 template seems to solve the issue.
I’ll create a PR tonight for you to verify and hopefully you will allow a backport to the stable branch.
Olle Markljung
tis 26 maj 2015 kl. 15:51 skrev Olle Markljung <markljung@anonymised.com>:
Hello,
return result;
Olle Markljung
