I just made this PR [1] that fix this issue [2].
Currently when doing a layer preview of a coverage (or multiple coverages) filtering capabilities
(CQL, OGC and FeatureID) are deactivated, they are only active if a vector layer is present. My
PR changes that behavior to activate filtering capabilities if at least one of the used coverage
layers reader supports filtering (e.g. image mosaic).
I would like to backport this to GS 2.11.x right away, this issue is between a bug and an improvement.
The nature of the changes are additive and self contained to the Openlayers output format.
In the users point of view the only difference will be the possibility to use the filtering capabilities when
doing the preview of a coverage whose reader supports filtering.
Any objections to backporting right away ?
[1] https://github.com/geoserver/geoserver/pull/2494
[2] https://osgeo-org.atlassian.net/browse/GEOS-8263
Nuno Oliveira
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
Via di Montramito 3/A
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
