[Geoserver-devel] Layer preview filtering capabilities activation
+1
-Jukka Rahkonen-
Lähettäjä: Ian Turton [mailto:ijturton@…403…]
Lähetetty: 25. elokuuta 2017 17:31
Vastaanottaja: Ben Caradoc-Davies <ben@…4191…>
Kopio: Geoserver-devel geoserver-devel@lists.sourceforge.net
Aihe: Re: [Geoserver-devel] Layer preview filtering capabilities activation
I’d never noticed this but seems harmless +1
Ian
On 24 August 2017 at 23:29, Ben Caradoc-Davies <ben@…4191…> wrote:
+0. No objection here. While this is a slight behavioural change, it must be backwards compatible and I do not see how the new behaviour can cause any harm.
Kind regards,
Ben.
On 25/08/17 02:31, Nuno Oliveira wrote:
I just made this PR [1] that fix this issue [2].
Currently when doing a layer preview of a coverage (or multiple coverages) filtering capabilities
(CQL, OGC and FeatureID) are deactivated, they are only active if a vector layer is present. My
PR changes that behavior to activate filtering capabilities if at least one of the used coverage
layers reader supports filtering (e.g. image mosaic).
I would like to backport this to GS 2.11.x right away, this issue is between a bug and an improvement.
The nature of the changes are additive and self contained to the Openlayers output format.
In the users point of view the only difference will be the possibility to use the filtering capabilities when
doing the preview of a coverage whose reader supports filtering.
Any objections to backporting right away ?
[1] https://github.com/geoserver/geoserver/pull/2494
[2] https://osgeo-org.atlassian.net/browse/GEOS-8263
Director
Transient Software Limited <http://transient.nz/>
New Zealand
Geoserver-devel mailing list
Ian Turton
