[Geoserver-devel] Layer security: 403 as ADMIN (CATALOG_MODE.MIXED + OPAQUE LAYER GROUP)
I stumbled upon this problem and I would like to know if this is a bug
or a feature.
I'm starting on a GS 2.19.1 with fresh DATA_DIR. Setting
Security->CatalogMode to "MIXED". Then setting the LayerGroup tiger-ny
to OPAQUE.
When now hitting the layer "tiger:poi" (contained in tiger-ny) as user
"admin", I get a 403:
curl -u "admin:geoserver" -vv
"http://localhost:8088/geoserver/tiger/wms?service=WMS&version=1.1.0&request=GetMap&layers=tiger%3Apoi&bbox=-74.0118315772888%2C40.70754683896324%2C-74.00153046439813%2C40.719885123828675&width=641&height=768&srs=EPSG%3A4326&styles=&format=image%2Fpng"
< HTTP/1.1 403
Though as admin, shouldn't I access everything?
It burns down to DefaultResourceAccessManager:
https://github.com/geoserver/geoserver/blob/78c3fa4bf1094be6b9b54bfe8ccf33b222d64d07/src/main/src/main/java/org/geoserver/security/impl/DefaultResourceAccessManager.java#L237
if (directAccess && sg.getMode() == Mode.OPAQUE_CONTAINER) {
return false;
Is this intended? I would have expected a OWS LayerNotFoundException.
Cmp also https://github.com/geoserver/geoserver/wiki/GSIP-153.
Björn
*camptocamp*
INNOVATIVE SOLUTIONS
BY OPEN SOURCE EXPERTS
*Björn Höfling*
GIS engineer
+49 89 26 20 89 9922
*bjoern.hoefling@anonymised.com <bjoern.hoefling@anonymised.com>*
GPG Key: 9E6D57C03ACED804DA5973DBBC5CE91F611B147B
*Camptocamp Germany GmbH*
Gustav-Heinemann-Ring 123
81739 München
Deutschland
https://careers.camptocamp.com/de <http://www.camptocamp.com/de&gt;
Hi Andrea,
On Thu, Jul 8, 2021 at 4:10 PM Andrea Aime <andrea.aime@anonymised.com> wrote:
On Wed, Jun 23, 2021 at 11:22 AM Björn Höfling <bjoern.hoefling@anonymised.com> wrote:
or a feature.
Who knows... mixed mode is the "weird one" that does not get used all that often :smiley:
I'm guessing it's just emergent behavior, rather than something planned (but I'm not sure, it's been a long while).
That said, in mixed mode, layers a user is not supposed to see are removed from
the capabilities document, but trigger a 403 in case they are accessed directly.
to OPAQUE.
"http://localhost:8088/geoserver/tiger/wms?service=WMS&version=1.1.0&request=GetMap&layers=tiger%3Apoi&bbox=-74.0118315772888%2C40.70754683896324%2C-74.00153046439813%2C40.719885123828675&width=641&height=768&srs=EPSG%3A4326&styles=&format=image%2Fpng&quot;
< HTTP/1.1 403
But, as admin, you set the group as an opaque container, so the layers should not be accessible, not even to the admin.
An opaque container is not really a security config, even if implementation wise some bits might have ended up there...
and this may be the origin of the issue you're seeing.
return false;
The above check seems ok, the layer should not be accessible when in opaque mode. The exception you get, a 403, does not instead,
you are right, I would have expected a LayerNotFound too. The implementation likely needs fixing... off the top of my head, the fix
does not sound trivial, and the applicability of it, limited. Personally, I either use HIDE or CHALLENGE.
The practical solution here for us was to use HIDE mode.
Good to know you also find it non-trivial to solve it.
Björn
*camptocamp*
*Björn Höfling*
GIS engineer
81739 München
Deutschland
