[Geoserver-devel] Layout change in GeoServer main pages
just want to point out a proposed layout change in pages sporting command links with a table below them (e…g, stores, layers, styles and so on):
https://github.com/geoserver/geoserver/pull/5314
Personally I don’t mind either way, but since it affects everyone’s usage of GeoServer (and material that involves screenshots, including our docs) I think it’s best if it gets exposure and eventual discussion before being merged.
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 333 8128928
Thanks Andrea,
I think any existing screen shots will still be understandable as the icons + labels are the same; just making for less scrolling.
Click through to the pull request for screen shots.
Jody
Jody Garnett
A pull request from the FOSS4G code sprint updates some of the screen shots:
https://github.com/geoserver/geoserver/pull/5322
Jody Garnett
Nice, thanks for the update!
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
