[Geoserver-devel] ldap authentication provider & role service
Hello Mauro and Mailing List,
It appears to me that the LDAP authentication provider and role service currently are unable to be used simultaneously.
This is because the active role service is queried from the method RoleCalculator.calculateRoles. This method is normally called from the authenticator you use to log in to geoserver. However, the LDAP authenticator does not call this method. Therefore, when you log on with LDAP, the active role service is never used to assign roles to the user you are logging in with. Because of that the ADMIN and GROUP_ADMIN settings in the role service don't have any effect when using the ldap auth.prov. (or any other role mappings).
I have made a patch for this problem:
https://github.com/geoserver/geoserver/pull/928
Please have a look if that makes sense to you.
Kind Regards
Niels
On 12-02-15 19:20, Mauro Bartolomeoli wrote:
Hi Niels,
2015-02-12 19:11 GMT+01:00 Niels Charlier <niels@anonymised.com <mailto:niels@anonymised.com>>:
    Trying to wrap my head around the LDAP security configuration and
    I'm looking for someone who knows about this.
    I've read:
    http://docs.geoserver.org/latest/en/user/security/tutorials/ldap/index.html
    But I noticed that the following settings can be configured both
    in the authentication provider and the role service:
    1) group base and filter
    2) names of the ADMIN and GROUPADMIN roles;
    What is the difference between those different but similar looking
    settings?
They have the same meaning, but since the services are of different type, they are available in both services.
    What additional behaviour does the role service provide?
The role service allows you to get the roles list from LDAP so that you can bind permissions (service or layer) to a role coming from LDAP.
    I thought the role service was to map the roles to ldap groups,
    but the tutorial says that the settings in the auth.prov. do that
    as well.
Yes, in case of LDAP you can do roles mapping directly from the authentication provider, so the role service is not needed for that if you use the auth provider configuration.
    And what do you get from specifying admin and groupadmin in the
    role service on top of doing it in the auth.prov?
I think that in case you configured role mapping from the auth provider, that one wins, so it is probably not mandatory to have it also in the role service.
Take into account that, in general, the authentication provider and the role service are independent. In theory you can use an LDAP roleservice also with a not LDAP auth provider (I don't have a real use case at the moment, but in theory this is possible).
At the end if you use both in a standard way, the LDAP role service is needed to list (and use) the roles from LDAP in the authorization section.
Mauro
Dott. Mauro Bartolomeoli
@mauro_bart
Senior Software Engineer
Via Poggio alle Viti 1187
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
Hi Niels,
2015-02-17 15:43 GMT+01:00 Niels Charlier <niels@anonymised.com.2918…>:
This is because the active role service is queried from the method RoleCalculator.calculateRoles. This method is normally called from the authenticator you use to log in to geoserver. However, the LDAP authenticator does not call this method. Therefore, when you log on with LDAP, the active role service is never used to assign roles to the user you are logging in with. Because of that the ADMIN and GROUP_ADMIN settings in the role service don’t have any effect when using the ldap auth.prov. (or any other role mappings).
I made some comments on the pr. The main one is that some unit tests are needed.
Thanks
Mauro
@mauro_bart
Hi Mauro,
Thank you for your quick review. I have added a unit test that tests the changes.
Also note my reply to your other comment in the old diff. I have now removed this change form the patch because it was a totally unrelated to the bug. But I still wish to make a note for the future that this might be a desired change to make the configurations more consistent with each other (see comments in pull request for details).
On that note, I have also discovered a different issue with the RoleServiceTest, most of the test methods are skipped because once you have done one test method, the port of the test ldap server is still open and the assume command fails for each of the other test methods. I think there is some cleaning up necessary to get that test properly operative.
Thanks again for your quick assistance.
Kind Regards
Niels
On 17-02-15 17:47, Mauro Bartolomeoli wrote:
Hi Niels,
2015-02-17 15:43 GMT+01:00 Niels Charlier <niels@anonymised.com <mailto:niels@anonymised.com>>:
Thanks
Mauro
@mauro_bart
Hi Mauro,
I've got yet another (small) patch. One particular user was unable to map roles with the authentication provider. After a long search we figured out it was because the user had a colon (":") in their password. The authority populator now uses a colon to attach and separate a user from its password, which is not such a safe method.
Patch:
https://github.com/NielsCharlier/geoserver/commit/3b8c4aab7a2ae32b55fd546cdce279267c757938
Thanks!
Kind Regards,
Niels
Hi Niels,
Thanks
Mauro
@mauro_bart
Hi Niels,
the patch looks good to me, please merge it into master.
Mauro
2015-02-21 17:34 GMT+01:00 Niels Charlier <niels@anonymised.com>:
Hi Mauro,
I’ve got yet another (small) patch. One particular user was unable to map roles with the authentication provider. After a long search we figured out it was because the user had a colon (“:”) in their password. The authority populator now uses a colon to attach and separate a user from its password, which is not such a safe method.
Patch:
Thanks!
Kind Regards,
Niels
Hi Niels,
2015-02-17 15:43 GMT+01:00 Niels Charlier <niels@anonymised.com>:
Thanks
Mauro
@mauro_bart
@mauro_bart
