[Geoserver-devel] LDAP tests and JDK11
I did some investigation on updating our LDAP test infrastructure to be compatible with JDK11.
The main obstacle is the embedded LDAP server (apacheds) we use for testing.
The current one uses some deprecated classes sun.*, so I tried upgrading to a newer version.
I found that 2.0.0-Mxx versions (there is no 2.0.0 final version yet) are compatible, but unfortunately tests execution times are not comparable (4-5 times slower), even with JDK8.
I don’t think it’s acceptable to have tests so slow to execute (40-50 seconds for each unit test), so unless we find a way to speed-up apacheds start time, or migrate to a different testing solution, I would leave the code untouched for now.
I pushed my work on branch of my fork: https://github.com/mbarto/geoserver/tree/jdk11_ldap_test
Mauro Bartolomeoli
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Dott. Mauro Bartolomeoli
@mauro_bart
Technical Lead
Via di Montramito 3/A
mobile: +39 393 904 1756
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
