Thanks for the reply. I agree - the geosever code (with the os x
specific code) is likely an addition to be more friendly but clashes
with the TJ code. Although, the documentation for the loadLibrary()
would indicate that calling it twice wouldn't produce the 2nd error
(although, that behavior is also likely correct as well!).
Will investigate a bit more...
Hi Dave,
just a quick mail as I see you did not get much follow up on this side of
the pond... we simply don't have OSX, sorry!
However it seems you might have tracked down the issue in the turbojpeg
library wrapper itself, which is
(afaik) distributed by the turbojpeg project.
And that's.. interesting, look at the code here:
https://github.com/libjpeg-turbo/libjpeg-turbo/blob/master/java/org/libjpegturbo/turbojpeg/TJLoader.java.in
Wondering if OSX requires a jar file that's different from the other
operating systems?
That would be rather weird from a java standpoint (I would recognize the OS
dynamically instead), and yet...
On Wed, May 25, 2016 at 3:06 AM, Dave Blasby <dblasby@anonymised.com>
wrote:
I was looking at LibJPEGTurbo on OS X and noticed a possible problem.
Over in TurboJpegUtilities#load()
public static final String LIBNAME = "turbojpeg";
static void load() {
try {
System.loadLibrary(LIBNAME); // If this method is called
more than once with the same library name, the second and subsequent
calls are ignored.
if (LOGGER.isLoggable(Level.INFO)) {
LOGGER.info("TurboJPEG library loaded ("+LIBNAME+")");
} catch (java.lang.UnsatisfiedLinkError e) {
String os = System.getProperty("os.name").toLowerCase();
if (os.indexOf("mac") >= 0) {
System.load("/usr/lib/libturbojpeg.jnilib");
} else {
throw e;
On OS X, the first System.loadLibrary(LIBNAME) fails, but it succeeds
with the System.load("/usr/lib/libturbojpeg.jnilib");
However, for the TurboImageWorkerTest#writer test, it eventually gets down
to
TurboJpegImageWriter line 196;
compressor = new TJCompressor();
However, TJCompressor (line 456) - part of the
turbojpeg-wrapper-1.2.1.1 jar - has a static initializer;
static {
TJLoader.load();
final class TJLoader {
System.loadLibrary("turbojpeg");
This throws the UnsatisfiedLinkError exception (as above).
Is anyone getting the tests to run on OS X with libjepgturbo installed?
The API documentation for System.loadLibrary(name) says;
The call <code>System.loadLibrary(name)</code> is effectively
equivalent to the call
Runtime.getRuntime().loadLibrary(name) " which (as noted in the
comments, above) says "If this method is called more than once with
the same library name, the second and subsequent calls are ignored.".
However, this throws the exception twice;
try {
So does this;
try{
Runtime.getRuntime().loadLibrary("turbojpeg");
$ java -version
java version "1.8.0_60"
Java(TM) SE Runtime Environment (build 1.8.0_60-b27)
Java HotSpot(TM) 64-Bit Server VM (build 25.60-b23, mixed mode)
Is anyone having troubles with LibJPEGTurbo on OS X? I expect it's
fine on other OSes.
Dave
Mobile security can be enabling, not merely restricting. Employees who
bring their own devices (BYOD) to work are irked by the imposition of MDM
restrictions. Mobile Device Manager Plus allows you to control only the
apps on BYO-devices by containerizing them, leaving personal data
untouched!
Download Mobile Device Manager Plus | Mobile Device Manager Plus
Geoserver-devel mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
x.com
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i
file/s allegato/i sono da considerarsi strettamente riservate. Il loro
utilizzo è consentito esclusivamente al destinatario del messaggio, per le
finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
via e-mail e di procedere alla distruzione del messaggio stesso,
cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per
finalità diverse, costituisce comportamento contrario ai principi dettati
dal D.Lgs. 196/2003.
information in this message that has been received in error. The sender does
not give any warranty or accept liability as the content, accuracy or
