[Geoserver-devel] Library for retrieving system level and hardware info
I would like to use the oshi library [1] in the context of GeoServer to retrieve system-level (maybe hardware info), its license is EPL.
Does anyone sees any problem ?
Oshi has a nice API and allow us to retrieve information about the system and is hardware [2]. This library uses JNA and no extra DLL needs to be installed. Major operating systems (Windows, Linux, Mac OS X and Unix based systems) are supported.
Of all the existing alternatives for doing this in Java oshi seems to be the better option, oshi GitHub page provides a good summary about those alternatives [3]. Sigar [4] seems to be dead (the main page doesn't responds anymore) and it requires a DLL to be installed. JHardware [5] only has a single contributor, is mor elimited than oshi and Mac OS X seems to not be supported. Java OperatingSystemMXBean [6] doesn't provide much information and will probably not play well with non oracle JVM, although OpenJDK seems to support it.
Nuno Oliveira
[1] https://github.com/oshi/oshi
[2] https://github.com/oshi/oshi/blob/master/oshi-core/src/test/java/oshi/SystemInfoTest.java
[3] https://github.com/oshi/oshi#how-is-this-different-from-
[4] https://github.com/hyperic/sigar
[5] https://github.com/profesorfalken/jHardware
[6] http://docs.oracle.com/javase/8/docs/jre/api/management/extension/com/sun/management/OperatingSystemMXBean.html
Visit http://goo.gl/it488V for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
Via di Montramito 3/A
mob: +39 333 8128928
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i file/s allegato/i sono
da considerarsi strettamente riservate. Il loro utilizzo è consentito esclusivamente al destinatario del messaggio, per le finalità indicate
nel messaggio stesso. Qualora riceviate questo messaggio senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia via e
-mail e di procedere alla distruzione del messaggio stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità diverse, costituisce comportamento contrario ai
  The information in this message and/or attachments, is intended solely for the attention and use of
the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree
June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying,
distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named
addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the
information in this message that has been received in error. The sender does not give any warranty or accept liability as the content,
accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which
arise as a result of e-mail transmission, viruses, etc.
On another project I work on we use the sigar library, but as you mention it’s gone dead so we’re switching to OSHI. I’ve done some initial experimentation with it and find it works great without all of the fuss of JNI that sigar brings along. It looks like you’re going that way regardless but I definitely recommend it.
On Thu, Apr 27, 2017 at 7:15 AM Nuno Oliveira <nuno.oliveira@anonymised.com> wrote:
alternatives [3]. Sigar [4] seems to be dead (the main page doesn’t
seems to not be supported. Java OperatingSystemMXBean [6] doesn’t
Nuno Oliveira
[2]
[6]
@nmcoliveira
Software Engineer
June, 30 2003, no.196 - Italy’s New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying,
Geoserver-devel mailing list
Ah! nice thanks for the feedback Justin.
Nuno Oliveira
[2]
[6]
@nmcoliveira
Software Engineer
Visit [http://goo.gl/it488V](http://goo.gl/it488V) for more information.
@nmcoliveira
Software Engineer
[http://www.geo-solutions.it](http://www.geo-solutions.it)
[http://twitter.com/geosolutions_it](http://twitter.com/geosolutions_it)
EPL is taking some steps to get along better with GPL. For now we have a clause in our License for eclipse libraries.
Is this an eclipse library?
On Thu, Apr 27, 2017 at 8:54 AM Nuno Oliveira <nuno.oliveira@anonymised.com> wrote:
Nuno Oliveira
[2]
[6]
@nmcoliveira
Software Engineer
@nmcoliveira
Software Engineer
engaging tech sites, Slashdot.org! http://sdm.link/slashdot_______________________________________________
Jody Garnett
Hi Jody,
Thanks for the feedback.
What is an eclipse library, something that is build \ published by Eclipse foundation ? In that case I don’t think this is an Eclipse library.
What are the options in this situation, or there is no options an this library cannot be used with GS ?
Nuno Oliveira
[2]
[6]
@nmcoliveira
Software Engineer
@nmcoliveira
Software Engineer
Jody Garnett
@nmcoliveira
Software Engineer
The option is we make a change request and modify that license page :slight_smile:
I note the next version of EPL will have an option projects can use to get along with GPL.
On Fri, Apr 28, 2017 at 2:15 PM Nuno Oliveira <nuno.oliveira@anonymised.com> wrote:
Hi Jody,
Nuno Oliveira
[2]
[6]
@nmcoliveira
Software Engineer
@nmcoliveira
Software Engineer
Jody Garnett
@nmcoliveira
Software Engineer
Jody Garnett
Ciao Jody,
I know you are trying to help (and I thank you for that) but you are
bringing confusion rather
than clarity; You are not only speaking to native english speakers,
bear that in mind! :slight_smile:
Nuno, what Jody is trying to say (correct me Jody if I am wrong) is that
since this is EPL 1.0 licensed code, likewise other libraries we ship
with GeoServer (namely MEF), we just need to change the license page
in GeoServer
(I am simplifying here) to mention it.
Correct?
Simone Giannecchini
[1] https://github.com/geoserver/geoserver/blob/c011bc2e76a480ab582f2eeb0dab34ebd60fd21f/LICENSE.txt#L342
Ing. Simone Giannecchini
@simogeo
Founder/Director
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
messaggio, per le finalità indicate nel messaggio stesso. Qualora
cortesemente di darcene notizia via e-mail e di procedere alla
Conservare il messaggio stesso, divulgarlo anche in parte,
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
for the attention and use of the named addressee(s) and may be
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
disclosure, reproduction, copying, distribution, or either
previous formal approval of the named addressee(s). If you are not the
telephone, fax or e-mail and delete the information in this message
or accept liability as the content, accuracy or completeness of sent
were sent or for other risks which arise as a result of e-mail
On Sat, Apr 29, 2017 at 7:52 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
along with GPL.
Hi Jody,
Eclipse foundation ? In that case I don't think this is an Eclipse library.
Nuno Oliveira
[2]
[6]
@nmcoliveira
Software Engineer
Check out the vibrant tech community on one of the world's most
@nmcoliveira
Software Engineer
Jody Garnett
@nmcoliveira
Software Engineer
Jody Garnett
