[Geoserver-devel] link urls to spatial attributes
I am using geoserver and think that it is great - easy to set up and does everything that you've claimed that it should do. I am building a web mapping interface with mapbuilder and would like to expose points (stored in a point shapefile) which can be clicked on - directing the browser to the url stored in the shapefile attribute. I've done this in the past with the mapserver, and would like to do the same with geoserver/map builder. Does anyone have any experience building this sort of system? Thanks. John
I believe this is more of a question for mapbuilder - all we can really
do from the geoserver side is to have one of the attributes be a url.
I don't think mapbuilder quite supports this, but pretty easily could
with a bit of modification. I started playing with it a bit, got some
good advice on how to do it, but never finished it up. Mapbuilder
guys, you have a wiki tutorial for doing something like this yet?
Chris
Quoting John Harris <harris@anonymised.com>:
a
in
This SF.Net email is sponsored by:
Power Architecture Resource Center: Free content, downloads,
discussions,
and more. http://solutions.newsforge.com/ibmarch.tmpl
Geoserver-devel mailing list
This mail sent through IMP: https://webmail.limegroup.com/
Dave Blasby has a little demo that does what you want.
You have to deploy Geoserver with the 'tiger_and_apps' type selected. You will need the source code to do this:
    In build.properties, set value of test.type to tiger_and_apps
    For example: test.type=tiger_and_apps
    Save it.
    Run the ant script 'debug from ide' to build Geoserver.
    This will deploy with the extra data.
Run Geoserver, then go to http://localhost:8080/geoserver/data/popup.html
If you can't get that working, then take a look at the file I have attached. It does most the work.
Brent Owens
TOPP
John Harris wrote:
Power Architecture Resource Center: Free content, downloads, discussions,
(attachments)
popup.html (27.2 KB)
Thanks Brent,
I looked at the mapbuilder api and the code and think that redirecting the browser to the url stored in the 'url' attribute of a shapefile is totally doable and I plan on doing it once I can successfully access the information in the shapefile via geoserver. I spent a couple hours trying to expose all the shapefile attributes through geoserver so that I could use the 'GetFeatureInfo' call to get the attributes. Everything seems fine -- my shapefile is exposed and all the attributes are showing up:
http://nebulous.msi.ucsb.edu:8080/geoserver/wfs?request=GetFeature&typename=topp:metacat_testdata
and I modified the mapbuilder wfs-t demo to show these data at:
http://nebulous.msi.ucsb.edu:8080/geoserver/data/mbdemos/demo/metacat_wfs/index.html
but, I can't seem to get the attributes of the shapefile to display -- infact when I hit the 'info' button there is no call at all made to the servlet.
my config.xml contains these lines:
<GetFeatureInfo id="getFeatureInfo">
     <buttonBar>mainButtonBar</buttonBar>
     <targetModel>mainMap</targetModel>
     <!-- <targetModel>featureCollection</targetModel> -->
     <context>mainMap</context>
     <mouseHandler>mainMouseClick</mouseHandler>
     <!-- <mouseHandler>mainAoi</mouseHandler> -->
     <class>RadioButton</class>
     <enabledSrc>/images/QueryEnable.gif</enabledSrc>
     <disabledSrc>/images/QueryDisable.gif</disabledSrc>
</GetFeatureInfo>
I've attached the config file and the metacat.xml file that is referenced. Is there a demo showing how to do this with geoserver? I noticed a really nice example at:
http://maps.hostgis.com/harbor/mapbuilder/demo/harbor2/
and looked at their code and it seems to be pretty much the same as mine (yet theirs uses mapserver). Thanks for your help. John
   Save it.
Brent Owens
TOPP
John Harris wrote:
    OpenPlans.org Geoserver WFS/WMS Demonstration Application
Zoom Out
up
down
      DEBUG LOG
John Harris
Numeric Solutions, LLC.
2506 Bayshore Ave Ventura, CA 93001
805.407.7644
http://www.numericsolutions.com
I've started a Mapbuilder WFS tutorial at:
http://docs.codehaus.org/display/MAP/WFS+Tutorial
Let me know if it needs more information.
do from the geoserver side is to have one of the attributes be a url. I don't think mapbuilder quite supports this, but pretty easily could
Chris
a
in
discussions,
mapbuilder-devel mailing list
mapbuilder-devel@lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/mapbuilder-devel
Cameron Shorter
http://cameron.shorter.net
http://mapbuilder.sourceforge.net
