me and Alessio are looking for a way to perform a live backup and restore
of the GeoServer data directory without having to stop the instance.
Now, there is a number of issues to be faced but let me start with the
major one: concurrent catalog modifications.
During a backup nothign should be able to write, during a restore nothing
should be able to even read.
Actually the same problem occurs in GeoServer today in other occasions
and I have the impression it's also the cause of those null pointer exceptions
that are getting reported on the user list:
- concurrent admin operations, either via GUI or REST (hello Justin and his
multi-admin proposal)
- concurrent reload/reset operations (eventually with other stuff going on)
Now, if every single configuration bit was in a db and we had a
transaction api for
config changes this would not be a problem, but we're not there yet,
and that would require a very significant investment that we don't have
the funding for, so we are going to propose a simpler solution instead.
What about a global configuration read/write lock? GS 1.7 used to have it.
At the very least GUI and REST config would take a read lock when accessing
configuration data, and a write lock every time they are about to write on
the catalog, to protect the whole sequence of oprations and the associated
side effects happening via catalog/configuration listeners.
Reload would get a write lock, reset a read one.
The backup operation (probably implemented via rest) a read one, the restore
one a write one.
OGC operations might also get a read lock, that would prevent at least part
of the reasons why the stores die on their back while they are running
(the other would be the lru cache pushing out the stores, that's another story).
However I'm concerned that a long WFS download or a long WPS request
might make the configuration untouchable for a very long time.
So we might want to let these fail in face of configuration changes.
Btw, backup wise we'd like to backup the entire data directory (data, fonts,
styling icons and whatnot included), and restore
would wipe it out, replace it with the new contentes, and force a reload.
GWC is actually putting a wrench in this plan since it keeps a database open,
wondering if there is any way to have it give up on the db connections
for some time?
As an alternative we could have the backup and restore tools work on
selected directories
and files, configurable in the request (which could be a post) and
with some defaults
that only include the gwc xml config file, I guess GWC would
just reconfigure itself after the reload and wipe out the caches, right?
Anyways... opinions? Other things that might go pear shaped that we
did not account for?
Ing. Andrea Aime
Tech lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
http://www.youtube.com/user/GeoSolutionsIT
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
