[Geoserver-devel] Log4j Properties file
From the log4j.properties file of the release version:
log4j.appender.logfile.File=/home/ENV/sfarber/dev/geoserver/data_dirs/gs-config-1.6.x/logs/geoserver.log
(I was setting up the commons-logging for JTileCache, so I was going to copy Geoserver's properties... well, most of them anyway. Since it does work normally, I take it that the value is programatically set somewhere later on?)
-- Chris Whitney
log4j.appender.logfile.File=/home/ENV/sfarber/dev/geoserver/data_dirs/ gs-config-1.6.x/logs/geoserver.log
Ha ha, I guess it's a leftover... well, once we get the UI to
setup the logging configuration file, we should be gold.
My bad!
I'm about 2/3rds done with the log4j logging ui right now, so that should disappear soon. Problem with log4j.properties files is that it's hard to set the log file path in a machine-independent manner.
--saul
From: geoserver-devel-bounces@lists.sourceforge.net on behalf of Chris Whitney
Sent: Sat 6/30/2007 12:51 AM
To: Geoserver-devel
Subject: [Geoserver-devel] Log4j Properties file
-- Chris Whitney
This SF.net email is sponsored by DB2 Express
Download DB2 Express C - the FREE version of DB2 express and take
control of your XML. No limits. Just data. Click to get it now.
http://sourceforge.net/powerbar/db2/
Geoserver-devel mailing list
