months ago Jody wrote a proposal to upgrade Log4j to the latest version (2.x), the proposal is still here
but has had little discussion and no voting:
https://github.com/geoserver/geoserver/wiki/GSIP-167
Upgrading log4j has little problems code wise, the API is a bit different, but not so much, and it affects
only projects using it directly, that is, geowebcache and maybe geofence. It is also supposed to be faster
and have more options, like asynch logging, so I’d be personally happy to see it happening.
The main issue with the upgrade is that log4j 2 is a complete rewrite and it uses a rather different configuration
syntax, which means, we’ll have to change how logging is configured in the data directory.
Currently log4j2 supports different configuration syntaxes:
XML: https://logging.apache.org/log4j/2.x/manual/configuration.html#XML
JSON: https://logging.apache.org/log4j/2.x/manual/configuration.html#JSON
YAML: https://logging.apache.org/log4j/2.x/manual/configuration.html#YAML
Properties: https://logging.apache.org/log4j/2.x/manual/configuration.html#Properties
The properties syntax is not the same as log4j 1.x and there is no facility to migrate from the old config files,
here we’ll have to make a backwards incompatible change.
Now, which config syntax to use for the new system?
There is a debate on gitter, so far with two camps:
- Kevin dislikes properties and would like to use YAML
- Ian would prefer properties over YAML.
- I just hate YAML in a most irrational, from the bones out, complete way, and will take anything but it, with a preference for property files
Migration wise, I believe the easiest thing would be to have a different log configuration directory, e.g., from “logs” to “logging” (to match the config file
that controls the logging configuration), and if empty or missing, we’d fill it with the config files form the WAR, like we do today.
Using a different folder I also hope we’d be free to accept whatever config syntax (to be verified) with no conflicts and the discussion
about would be limited to what we use for the default config file samples.
Regardless, it seems that we have to discuss and vote on Jody’s GSIP right now…
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
