[Geoserver-devel] logging patch for GEOS-2284
Hi folks,
I submitted a patch for GEOS-2284. What this patch does preserver any non file and non console appenders when configuring or reconfiguring GeoServer logging. The rationale being to allow other appenders to remain in tact.
My specific use case here is for the mac installer. Since on mac os starting GeoServer or an application won't fire up a console to capture the logs I needed another way to capture them. However as soon as logging in gs gets configured my appender is wiped out.
So, so if someone could review the patch for me that would be great. Thanks.
-Justin
Justin Deoliveira
OpenGeo - http://opengeo.org
Justin Deoliveira ha scritto:
Hi folks,
Here we go. Hum, logging should not be configured with
GeoServer.configureGeoServerLogging, after the changes for
http://jira.codehaus.org/browse/GEOS-1671 nothing is using that method anymore (at least on my checkout), and afaik it wasn't used by startup
code even before that change (only test setup used it).
The code that actually does something is in LoggingInitializer, the
method is basically the same.
Besides this the patch looks good to me.
Andrea Aime
Hi folks,
Ah, one more thing. The forward port on trunk requires patching a different class, as on trunk the logging is configured in a utility
class, LoggingUtils, so that the code can be shared between the
LoggingStartupContextListener (that configures logging before anything
else has a chance to use it) and the LoggingInitializer (that adds
a listener reconfiguring loggin when the user changes the config in
the UI). (trunk is doing "the right thing" but you asked me not
to backport the fuller solution to avoid harming stability, so we
have different code on 1.7.x and trunk).
Andrea Aime
Right, forgot about that. This patch is a couple of months old so it was done before that change. I will update it to reflect the new way of things. Also do need to keep the method on GEoServer around? Should we kill it. Maybe just mark it with a big nasty comment for now.
Justin Deoliveira
Cool, thanks for the heads up.
Justin Deoliveira
I actually would just kill it, it's not like GeoServer is exposing
an API that we need to keep stable from release to release.
Let's use this freedom while we can :wink:
Andrea Aime
