[Geoserver-devel] Logical (Boolean) data type in shapefiles
I was reading this http://jira.codehaus.org/browse/GEOT-2689 about shapefiles which has value “?” in a field of type Logical and then with poor success this
http://www.javadocexamples.com/java_source/org/geotools/data/shapefile/ShapefileDataStore.java.html
I would like to know how Geotools is interpreting Logical field which contains “?”.
By reading this http://www.clicketyclick.dk/databases/xbase/format/data_types.html ? should mean Not initialised (default) (NULL). As mentioned, some sources tell that space 0x20 is used to mean NULL http://dbase.com/Knowledgebase/INT/db7_file_fmt.htm
Some sources seem to use “initialized” and some others “not initialized” in a meaning of “default, NULL”. For me the correct behavior might be
In reading:
? or space → NULL
Y, y, T, t → TRUE
N, n, F, f → FALSE
In writing:
NULL → ?
TRUE → T
FALSE → F
-Jukka Rahkonen-
