[Geoserver-devel] looking into build failure on maintenance branch
The maintenance branch has been down for a bit …
Last release was #164 - I will build locally and see what I can find.
I know we only have one more release scheduled before these jobs are shut off - but since I am on the hook for GeoServer 2.6.5 I would like to make sure it builds.
Jody Garnett
On Thu, Aug 6, 2015 at 12:39 AM, Jody Garnett <jody.garnett@anonymised.com>
wrote:
The maintenance branch has been down for a bit ...
Yep, well aware, could not find the time to look into it so far.
<http://ares.opengeo.org/jenkins/view/geoserver/job/geoserver-2.6.x/164/&gt; -
sure it builds.
So from the title you said you were looking into it... found anything?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
I ran the geotools, and then the geoserver build locally (in order) - and both succeeded.
Given that ares has a failure … I need to check into it more:
[INFO] Web Map Service Module … FAILURE [17.457s]
I wonder if 2.6.x is using perceptual diff, and thus my local build success is not indicative of the state of 2.6.x…
Does not look like it, the failure is:
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-wms: Compilation failure
[ERROR] /var/lib/jenkins/workspace/geoserver-2.6.x/src/wms/src/main/java/org/geoserver/wms/WMSMapContent.java:[219,49] error: cannot access MapViewport
Wonder if this build is using an older version of Java … nope Java 7.
The WMSMapContent.java code does not look suspicion:
ReferencedEnvelope dataArea = getViewport().getBounds();
Looking at the file directly on Ares (may need login for this link) WMSMapContent.java also looks correct.
So yeah, still not sure about the failure.
On Thu, Aug 6, 2015 at 12:39 AM, Jody Garnett <jody.garnett@anonymised.com3…> wrote:
So from the title you said you were looking into it… found anything?
Ing. Andrea Aime
@geowolf
Technical Lead
On Thu, Aug 6, 2015 at 8:15 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
both succeeded.
Yep, that's what I did as well the first time it failed... same result (and
then I gave up).
Given that ares has a failure ... I need to check into it more:
[INFO] Web Map Service Module ............................ FAILURE
[17.457s]
success is not indicative of the state of 2.6.x...
[ERROR]
Wonder if this build is using an older version of Java ... nope Java 7.
<https://github.com/geoserver/geoserver/blob/2.6.x/src/wms/src/main/java/org/geoserver/wms/WMSMapContent.java#L219&gt;
WMSMapContent.java
<http://ares.opengeo.org/jenkins/view/geoserver/job/geoserver-2.6.x/ws/src/wms/src/main/java/org/geoserver/wms/WMSMapContent.java&gt; also
looks correct.
Weird... maybe bad geotools jar file on the server?
Just kicked a 12.x build manually, let's see if that helps
Ing. Andrea Aime
@geowolf
Technical Lead
Think 2.6.x is still referring to the codehaus repo? And thus getting tripped up downloading dependencies?
On 5 August 2015 at 23:35, Andrea Aime <andrea.aime@anonymised.com> wrote:
Jody Garnett
Yep, that’s what I did as well the first time it failed… same result (and then I gave up).
Weird… maybe bad geotools jar file on the server?
Just kicked a 12.x build manually, let’s see if that helps
Ing. Andrea Aime
@geowolf
Technical Lead
On Thu, Aug 6, 2015 at 8:55 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Hum... why not sure the local jars though? Anyways, it's an easy to test
theory, remove the
codehaus link and see
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Jody,
it seems that forcing the build of geotools solved the issue, at least for today:
http://ares.boundlessgeo.com/jenkins/view/geoserver/job/geoserver-2.6.x/171/
On Thu, Aug 6, 2015 at 9:20 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hum… why not sure the local jars though? Anyways, it’s an easy to test theory, remove the
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Great a heisenbuild :slight_smile:
On 6 August 2015 at 01:47, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Jody,
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
