since we're going to release next week it should
be freeze time.
Which does not mean no commits at all btw, it means
no commits unless you're fixing a critical bug
Andrea Aime
OpenGeo - http://opengeo.org
It looks like we've managed to get from two blocking issues last week down to two new blocking issues this week:
http://jira.codehaus.org/browse/GEOS-3729
http://jira.codehaus.org/browse/GEOS-3702
And Ben has flagged another in GeoTools, which I believe was tagged earlier today:
http://jira.codehaus.org/browse/GEOT-2897
Andrea Aime wrote:
be freeze time.
Thanks, Mark.
should I indicate a blocking GeoTools issue in the GeoServer Roadmap, and if so, how should I do it? The Jira filter only reports GeoServer issues.
Should I file a GeoServer fix-version 2.0.1 issue to shadow the GT issue? Or is this just too much duplication?
Note: I'll be leaving in two and a half hours. Back in a month.
Kind regards,
Ben.
earlier today:
Andrea Aime wrote:
be freeze time.
This SF.Net email is sponsored by the Verizon Developer Community
Take advantage of Verizon's best-in-class app development support
A streamlined, 14 day to market process makes app distribution fast and easy
Join now and get one step closer to millions of Verizon customers
http://p.sf.net/sfu/verizon-dev2dev
Geoserver-devel mailing list
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer, CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
26 Dick Perry Ave, Kensington WA 6151, Australia
From what I recall there's precedent to filing a GeoServer issue that depends on the GeoTools issue for traceability.
Ben Caradoc-Davies wrote:
Thanks, Mark.
Kind regards,
Ben.
earlier today:
Andrea Aime wrote:
be freeze time.
It might be more straightforward to add a GeoTools Jira filter to the roadmap, and consider anything the is fix-version in the corresponding GeoTools release to block the GeoServer release.
Thanks, Mark.
issues.
Kind regards,
Ben.
earlier today:
Andrea Aime wrote:
be freeze time.
I'm ready to drop a tag and start the release today, but this blocker is still outstanding. Can anyone let me know what's happening with this issue and whether there's a plan to have it sorted out soonish?
Mark
Ciao Mark,
situation is as it is described in my last comment, that is IMHO that
problem does not really exists, again IMHO it is QGIS and othr GDAL
related software that is ignoring the pixel datum convetion for
geotiff data.
I am waiting for feedback from FrankW, meanwhile I would lower the
priority on this so that you can move forward.
Simone.
Ing. Simone Giannecchini
Founder - Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928
http://simboss.blogspot.com/
http://www.linkedin.com/in/simonegiannecchini
On Mon, Dec 21, 2009 at 12:41 AM, Mark Leslie <mark.leslie@anonymised.com> wrote:
Mark
Excellent, then I'll proceed with the release.
Thanks.
Simone Giannecchini wrote:
Ciao Mark,
geotiff data.
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Mark
Sorry for chiming in late on this one but one thing that i just forgot about was that for this release we have to make sure we announce some changes to the rest api. In order to fix a pretty major security hole gs now by default requires one to be authenticated in order to access any resources. Previously anonymous users had read only (GET) access.
Related is the addition of rest to the security sub system:
http://docs.geoserver.org/2.0.x/en/user/security/sec_rest.html
Anyways, something for a blog post but I wanted to ensure it got mentioned in the release notes because any clients relying on anonymous access will now be broken.
-Justin
Thanks.
Ciao Mark,
geotiff data.
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Mark
http://p.sf.net/sfu/verizon-dev2dev _______________________________________________
Justin Deoliveira
