[Geoserver-devel] macOS users important gitconfig changes
macOS users with an existing checkout, please check for updated Git Client Configuration
Linux and Windows users are unaffected.
Setting for macOS users (assuming case insensitive filesystem):
$ git config --global --get-regexp core.*
core.autocrlf input
core.safecrlf true
core.ignorecase false
core.precomposeunicode true
The above changes in bold allow macOS to match the behaviour of Linux.
Any macOS developers having difficulty updating their checkout:
error: The following untracked working tree files would be overwritten by merge:
data/citensg-1.0/workspaces/sf/sf/EntitéGénérique/featuretype.xml
data/citensg-1.0/workspaces/sf/sf/EntitéGénérique/layer.xml
data/citewfs-1.1/workspaces/sf/sf/EntitéGénérique/featuretype.xml
data/citewfs-1.1/workspaces/sf/sf/EntitéGénérique/layer.xml
data/citewfs-1.1/workspaces/sf/sf/EntitéGénérique/schema.xsd
data/citewfs-2.0/workspaces/sf/sf/EntitéGénérique/featuretype.xml
data/citewfs-2.0/workspaces/sf/sf/EntitéGénérique/layer.xml
Please move or remove them before you merge.
Can be fixed using:
git fetch upstream master
git reset --hard upstream/master
Thanks Michel and Torben for help testing.
Jody Garnett
I would like to back port this change to prior branches (and we should take care not to introduce these kind of differences in the future).
Jody Garnett
I have a PR for the 2.15.x branch here that fixes these folders: [backport 2.15.x] re-add select folders with precomposeunicode=true
(Master and 2.16.x were already fixed)
Jody Garnett
