Checking
- jetty-start-9.4.48.v20220622.jar is 154 KB
- distribution start.jar is 164 KB
MANIFEST.MF is identical )(same exported packages etc…)
Diff folders:
org/eclipse/jetty/start/Modules.class
org/eclipse/jetty/start/StartArgs.class
org/eclipse/jetty/start/shaded (only in distribution)
org/eclipse/jetty/start/shaded/util/JavaVersion.class
org/eclipse/jetty/start/shaded/util/ManifestUtils.class
org/eclipse/jetty/start/shaded/util/TopologicalSort.class
org/eclipse/jetty/start/shaded/util/TopologicalSort$CyclicException.class
org/eclipse/jetty/start/shaded/util/TopologicalSort$InitialOrderComparator.class
Which is odd …
- What does distribution do?
https://github.com/eclipse/jetty.project/blob/jetty-9.4.x/jetty-distribution/pom.xml
- uses ant run to do something
- unpacks jetty-home
- unpacks some wars
- has an assembly
https://github.com/eclipse/jetty.project/blob/jetty-9.4.x/jetty-home/pom.xml
- here it is a dependency on start using shade classifier
dependencies:
org.eclipse.jetty
jetty-start
${project.version}
shaded
maven-depeendency-plugin:
org.eclipse.jetty
jetty-start
${project.version}
shaded
jar
true
${assembly-directory}
start.jar
- so actually nothing special; just pulling a different classifier
https://github.com/eclipse/jetty.project/blob/jetty-9.4.x/jetty-start/pom.xml
- okay it defines more than one classifier
org.apache.maven.plugins
maven-shade-plugin
package
shade
false
true
true
shaded
So yeah, try pulling the same dependency as distribution:
org.eclipse.jetty
jetty-start
${project.version}
shaded
Jody Garnett
On Tue, 2 Aug 2022 at 07:57, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hmm… unsure.
I did try with this one:
https://mvnrepository.com/artifact/org.eclipse.jetty/jetty-start/9.4.48.v20220622
But the jar downloaded from that link does not work, Jetty won’t start.
What worked for me, was to grab the binary distribution, also available from maven repos, and then grabbing start.jar from it:
https://mvnrepository.com/artifact/org.eclipse.jetty/jetty-distribution/9.4.48.v20220622
and in particular this file:
https://repo1.maven.org/maven2/org/eclipse/jetty/jetty-distribution/9.4.48.v20220622/jetty-distribution-9.4.48.v20220622.zip
Unzip it, you’ll get a working start.jar.
On Tue, Aug 2, 2022 at 4:43 PM Jody Garnett <jody.garnett@anonymised.com> wrote:
Is there a maven dependency for that jar?
Jody Garnett
On Mon, 1 Aug 2022 at 10:47, Andrea Aime <andrea.aime@anonymised.com> wrote:
Trying to start a nightly I get:
ERROR : Nothing to start, exiting …
It seems the usual issue, start.jar has not been updated along with the
latest Jetty version upgrade.
We’d really need to either automate fetching that jar, and/or adding tests
to make sure the bin package is working properly (if that is done, it could open the interesting
possibility of also trying the start-up with each and every extension module, too).
In the meantime, this seems to do the trick:
https://github.com/geoserver/geoserver/pull/6083
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
Geoserver-devel mailing list
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
