[Geoserver-devel] Main branch is now requiring Java 11 for build
the switch to Java 11 being the minimum is now landed on all main branches of the geo-trio.
Stable and maintenance still have to build with Java 8 too so… careful with those backports!
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
