[Geoserver-devel] Make it clear what's up and down in the layer group page
every now and then we stumble into someone really confused about what layers is top
and bottom in the layer group page.
To someone that’s WMS savy and knows about the “painter model” there is little doubt,
the first layer is at the bottom, the last one at the top, but the vertical stacking of layers
in the dialog makes other think the first one is at the top.
Suggestions on how to improve things:
  • add a text warning right above or below the table
  • Have a “top” and “bottom” labels show in the table itself (bottom in the first row, top
    in the last one), since we are making
    one arrow disappear, maybe we could show the label in its place?
Feedback welcomed
Meet us at GEO Business 2014! in London! Visit http://goo.gl/fES3aK
for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
On Wed, Mar 19, 2014 at 10:14 AM, Andrea Aime
<andrea.aime@anonymised.com>wrote:
layers is top
To someone that's WMS savy and knows about the "painter model" there is
little doubt,
* add a text warning right above or below the table
* Have a "top" and "bottom" labels show in the table itself (bottom in the
first row, top
What about just reversing it so that the stacking order reflects the
presentation on the page and vice versa? If that doesn't make sense then I
think the label idea is a good one.
Feedback welcomed
Ing. Andrea Aime
@geowolf
Technical Lead
Learn Graph Databases - Download FREE O'Reilly Book
"Graph Databases" is the definitive new guide to graph databases and their
applications. Written by three acclaimed leaders in the field,
this first edition is now available. Download your free book today!
http://p.sf.net/sfu/13534_NeoTech
Geoserver-devel mailing list
*Justin Deoliveira*
Vice President, Engineering | Boundless
jdeolive@anonymised.com
@j_deolive <https://twitter.com/j_deolive&gt;
On Wed, Mar 19, 2014 at 5:42 PM, Justin Deoliveira <
the first row, top
I guess that will confuse those few that know about painter's model, and/or
understand the order in a layers=l1,l2,l3 request (we keep on saying that
layer group is
just being expanded into its layer list).
All in all I'd prefer to be explicit
Ing. Andrea Aime
@geowolf
Technical Lead
On Wed, Mar 19, 2014 at 10:46 AM, Andrea Aime
the first row, top
and/or understand the order in a layers=l1,l2,l3 request (we keep on saying
that layer group is
Works for me. Another thing that would help is to add a help icon to that
component with a pop up with a quick explanation of why the ordering is
like that. Same idea as on the workspace edit page where you specify
workspace local configuration.
Ing. Andrea Aime
@geowolf
Technical Lead
*Justin Deoliveira*
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
That would work on top of some other more visual solution. The problem is many people don’t click on those “?” help icons so they’re a “bonus” help rather than something to rely on to convey critical information.
Jonathan
Works for me. Another thing that would help is to add a help icon to that component with a pop up with a quick explanation of why the ordering is like that. Same idea as on the workspace edit page where you specify workspace local configuration.
On Fri, Mar 21, 2014 at 5:40 AM, Jonathan Moules <
many people don't click on those "?" help icons so they're a "bonus" help
Agreed, to be clearer I meant adding the help icon in addition to another
visual cue as well, so that if someone wonders why it says top at the
bottom and bottom at the top the help dialog could give them some insight.
Jonathan
*Justin Deoliveira*
On Fri, Mar 21, 2014 at 2:45 PM, Justin Deoliveira <
Works for me :slight_smile:
Ing. Andrea Aime
@geowolf
Technical Lead
Perhaps a “Render Order” column that indicates 4, 3, 2, 1 listing the explicit order the layers will be rendered? Then the Top = Bottom and Bottom = Top labels will make sense to people that need the numbering to see the direction/ordering of render.
Chris Snider
Senior Software Engineer
Intelligent Software Solutions, Inc.
Direct (719) 452-7257
Description: Description: Description: cid:image001.png@anonymised.com
On Fri, Mar 21, 2014 at 5:40 AM, Jonathan Moules <jonathanmoules@anonymised.com> wrote:
Agreed, to be clearer I meant adding the help icon in addition to another visual cue as well, so that if someone wonders why it says top at the bottom and bottom at the top the help dialog could give them some insight.
Jonathan
Justin Deoliveira
@j_deolive
On Fri, Mar 21, 2014 at 3:14 PM, Chris Snider <chris.snider@anonymised.com>wrote:
Perhaps a "Render Order" column that indicates 4, 3, 2, 1 listing the
Sure, a render order column is easily added.
Just wondering if people will make the instant association between "1" and
"bottom"
Ing. Andrea Aime
@geowolf
Technical Lead
Maybe we could replace the arrows for managing the ordering with icons that imply movement along a horizontal stack of layers, rather than a vertical one. while linking it to the vertical ordering of the list the right way around.
Something like this maybe: http://draconic.ca/~smithkm/path3767.png
On 21 March 2014 07:18, Andrea Aime <andrea.aime@anonymised.com> wrote:
Learn Graph Databases - Download FREE O’Reilly Book
“Graph Databases” is the definitive new guide to graph databases and their
Kevin Smith
Junior Software Engineer | Boundless
ksmith@anonymised.com
+1-778-785-7459
@boundlessgeo
On Fri, Mar 21, 2014 at 3:14 PM, Chris Snider <chris.snider@anonymised.com> wrote:
Just wondering if people will make the instant association between “1” and “bottom”
Ing. Andrea Aime
@geowolf
Technical Lead
right way around.
I like the idea, but we'd need a designer to make silk like icons with the
same concept
(full set here
http://www.famfamfam.com/lab/icons/silk/previews/index_abc.png)
Another issue is that silk icons are flat, not 3d
Ing. Andrea Aime
@geowolf
Technical Lead
On Thu, Mar 27, 2014 at 5:05 PM, Andrea Aime
same concept
(full set here
Uh, unless we use "shape_move_forward" and "shape_move_backwards", not
sure that will be clear for users though
Ing. Andrea Aime
@geowolf
Technical Lead
The problem with the silk forward and back buttons is that they don’t link the forward/back concept to position on the list. That’s why I exaggerated the vertical displacement of the overlapping pages and sloped the arrow at an angle. Switching to the existing forward and back buttons instead of up and down would help people make the right choice in terms of moving a particular layer, but it wouldn’t make it any more obvious how the order of the list related to the visual overlapping. In fact the silk icons go the wrong way with the forward shape higher than the rear shape.
Maybe if the blank spots for the up/forward button on the first row and down/backward button labels “front” and “back” instead of a blank space that would get the point across. Or maybe desaturated versions of the front and back buttons to indicate both that it can’t go further and why. Special versions of the silk forward/back buttons that have the forward shape lower might be a good idea too.
On 27 March 2014 09:07, Andrea Aime <andrea.aime@anonymised.com> wrote:
Kevin Smith
+1-778-785-7459
@boundlessgeo
On Thu, Mar 27, 2014 at 5:05 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Uh, unless we use “shape_move_forward” and “shape_move_backwards”, not
Ing. Andrea Aime
@geowolf
Technical Lead
I like the idea, but we’d need a designer to make silk like icons with the same concept
(full set here http://www.famfamfam.com/lab/icons/silk/previews/index_abc.png)
An alternate suggestion is to preview the layer group legend graphic on this page, then it will be a little more obvious what order the result is in? While it won’t necessarily be intuitive - I still like Justin’s idea of reversing the displayed order.
Jody Garnett
On 27 March 2014 09:07, Andrea Aime <andrea.aime@anonymised.com1268…> wrote:
Kevin Smith
+1-778-785-7459
@boundlessgeo
Ing. Andrea Aime
@geowolf
Technical Lead
ok everybody, how about this:
Inline image 1
Also, when you hover on the down arrow, a label appears “move to map top” and when you hover on the up arrow, you
get a “move to map bottom” message instead.
Good enough?
Adding the image is also possible, but it’s more work that it’s worth it in Wicket imho (one needs to program to add it, because
last time I checked the image needs to be retrieved out of the classpath… is there is a quick way to do that,
I’d be happy to hear it).
On Wed, Mar 19, 2014 at 5:14 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Feedback welcomed
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
On Fri, Mar 28, 2014 at 7:54 PM, Andrea Aime
!image.png|748x385
Ah, pull request here:
https://github.com/geoserver/geoserver/pull/550
Ing. Andrea Aime
@geowolf
Technical Lead
I like it. Personally I don’t love the idea of a big image to demonstrate the layer ordering. I think what you have done here is great.
(attachments)
On Fri, Mar 28, 2014 at 12:56 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Justin Deoliveira
@j_deolive
On Fri, Mar 28, 2014 at 7:54 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Inline image 1
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Andrea,
Maybe it’s a cultural thing, but personally I’d expect layer “1” to be on top and 4 to be on the bottom. However I guess if there’s a tooltip as you note that may work around that issue.
Jonathan
(attachments)
On 28 March 2014 18:54, Andrea Aime <andrea.aime@anonymised.com> wrote:
Inline image 1
Good enough?
Feedback welcomed
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Yes, it is culture and learned habits in our brains. Tell a 4-year old child to draw first a field and next add some cows and the order will be right. But we are so used to read row numbers from top to down on a paper print that we may really think that we would need to take a shovel and bury the cow.
-Jukka-
(attachments)
Jonathan Moules
Hi Andrea,
Jonathan
Inline image 1
Good enough?
On Wed, Mar 19, 2014 at 5:14 PM, Andrea Aime <andrea.aime@anonymised.com8…> wrote:
Feedback welcomed
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
On Mon, Mar 31, 2014 at 12:12 PM, Jonathan Moules <
Hi Andrea,
  Maybe it's a cultural thing, but personally I'd expect layer "1" to be
on top and 4 to be on the bottom. However I guess if there's a tooltip as
Here are the hovers, let's see if they help or not :slight_smile:
!Schermata del 2014-03-31 13:56:45.png|346x180
!Schermata del 2014-03-31 13:56:09.png|342x174
Ing. Andrea Aime
@geowolf
Technical Lead
