as you might now the latest GWC embedded in GeoServer allows to keep the disk quota subsystem in a relational database.
Part of the necessary information to connect to the db is username and password, which are stored using some GWC code based on XStream on disk.
Now, GWC has no notion of password encryption (with some good reason I’d say, since they only way to configure the stand-alone version is manual xml file editing), however it is bad that in GeoServer the same file has cleartext passwords when the rest of the system stores them encrypted.
So I was thinking, how about adding a PasswordEncoder interface to GeoWebCache that mimics, to a small extent, the GeoServer API?
interface org.geowebcache.security.PasswordEncoder {
// encrypt the value
String encode(String clearTextValue);
// check if the value has been encrypted by this encoder (GS uses prefixes to
// guess that afaik)
boolean isResponsibleFor(String encryptedValue);
// decodes the value, throws an exception if not encrypted by this encoder
String decode(String encryptedValue);
The idea is that in GWC we’d have one or more of these registered in the spring context, with a new config attribute marking one of them as the default one (and no password encoding happening if none is indicated) by bean name.
In GeoServer we’d have this configuration be locked onto a specific password encoder that is a bridge to the GeoServer own password encoding subsystem, which would delegate to ConfigurationPasswordEncryptionHelper to do the actual work.
Am I missing anything?
More in general, suggestions?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
