as you probably know our current GML2 output (GetFeature and GetFeatureInfo)
omits fully the elements whose value is null.
This causes issues in some dumb clients, such as javascript ones, as they may
show up a reduced set of attributes hiding the fact there are more.
Now, one could run a DescribeFeatureType but WFS might be not enabled,
and running an extra call might be undesirable anyways.
What problems do you see if we start returning an empty element instead of no
element at all for empty attributes? That is:
Do you believe we could just do that by default, or should it have a configuration
flag to enable/disable it?
Coding wise for GML2 generation the change is trivial (and it would really be
all I need, but I’m trying to think in more general terms).
GML3 wise uh… not sure. Maybe it’s just a matter of changing
GML3EncodingUtils.encodeSimpleContent, but I may be wrong
Opinions?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
mob: +39 339 8844549
Well this discussion came up actually before during the development of the wfs 1.1 spec and there were three options.
- omit the element
- create an empty element
- use the xs:nil construct
In the end (1) was decided upon. (2) I believe creates invalid xml documents and (3) I can’t remember.
So long story short this would go against the specification so not something we would want to do by default (perhaps by format_option?)
Then there is the question of other formats, like geojson which i believe apply the same method for null properties that are null (although i could be wrong).
On Wed, Aug 22, 2012 at 5:42 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Opinions?
Ing. Andrea Aime
@geowolf
Technical Lead
Live Security Virtual Conference
Exclusive live event will cover all the ways today’s security and
threat landscape has changed and how IT managers can respond. Discussions
will include endpoint security, mobile security and the latest in malware
threats. http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
On Wed, Aug 22, 2012 at 5:18 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
- omit the element
That’s odd? I’ve just tried to replace elements in a GeoServer WFS response with empty ones, as follows:
<wfs:FeatureCollection xmlns=“http://www.opengis.net/wfs”
xmlns:wfs=“http://www.opengis.net/wfs” xmlns:gml=“http://www.opengis.net/gml”
xmlns:GeoSolutions=“http://www.geo-solutions.it” xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance”
xsi:schemaLocation=“http://www.opengis.net/wfs http://demo1.geo-solutions.it:80/geoserver-enterprise/schemas/wfs/1.0.0/WFS-basic.xsd http://www.geo-solutions.it http://demo1.geo-solutions.it:80/geoserver-enterprise/GeoSolutions/wfs?service=WFS&version=1.0.0&request=DescribeFeatureType&typeName=GeoSolutions%3Acities”>
gml:boundedBy
gml:nullunknown</gml:null>
</gml:boundedBy>
gml:featureMember
<GeoSolutions:cities fid=“cities.1”>
GeoSolutions:the_geom
<gml:Point srsName=“http://www.opengis.net/gml/srs/epsg.xml#4326”>
<gml:coordinates xmlns:gml=“http://www.opengis.net/gml”
decimal=“.” cs=“,” ts=" ">-16.2617,28.4623</gml:coordinates>
</gml:Point>
</GeoSolutions:the_geom>
<GeoSolutions:TYPE />
<GeoSolutions:NATION />
GeoSolutions:CNTRYNAMESpain</GeoSolutions:CNTRYNAME>
GeoSolutions:LEVEL1</GeoSolutions:LEVEL>
GeoSolutions:NAMESanta Cruz de Tenerife</GeoSolutions:NAME>
<GeoSolutions:NAMEPRE />
<GeoSolutions:CODE />
GeoSolutions:PROVINCE38</GeoSolutions:PROVINCE>
GeoSolutions:PROVNAMESanta Cruz de Tenerife</GeoSolutions:PROVNAME>
GeoSolutions:UNPROV0</GeoSolutions:UNPROV>
<GeoSolutions:CONURB />
</GeoSolutions:cities>
</gml:featureMember>
</wfs:FeatureCollection>
Eclipse says the above document is valid (that GeoServer is available to the internet so you
can try out validation yourself)
Ing. Andrea Aime
@geowolf
Technical Lead
On Wed, Aug 22, 2012 at 6:07 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
gml:boundedBy
</gml:boundedBy>
gml:featureMember
</gml:Point>
Bah, it just took forever to validate, but indeed the result is invalid, have to look into why
Ing. Andrea Aime
@geowolf
Technical Lead
I think it depends on the type, indeed some types will allow for empty content (like strings) but others i believe do not. Or maybe i am just wrong about that…
On Wed, Aug 22, 2012 at 9:07 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
- omit the element
gml:boundedBy
</gml:boundedBy>
gml:featureMember
</gml:Point>
Ing. Andrea Aime
@geowolf
Technical Lead
Justin Deoliveira
On Wed, Aug 22, 2012 at 6:09 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
This variant seems to work fine though:
gml:boundedBy
</gml:boundedBy>
gml:featureMember
</gml:Point>
<GeoSolutions:TYPE xsi:nil=“true” />
<GeoSolutions:NATION xsi:nil=“true” />
Ing. Andrea Aime
@geowolf
Technical Lead
