[Geoserver-devel] Managing default value in wms dimensions, starting to get a number of ad-hoc solutions
right now we have two pull requests related to the management of the default
value in WMS dimensions:
  • jwood106 pull request https://github.com/geoserver/geoserver/pull/377 allows the
    specification of a specific value for elevation dimension over raster data.
    It changes the DimensionInfo API to store a specific value for the selected default.
  • ilkkarinne pull request https://github.com/geoserver/geoserver/pull/430 adds two
    different strategies to handle the default value of the time dimension, either choosing
    the latest value in the sequence, or the closest one to the time the WMS request was made.
    There is not configuration in this case, a system variable drives the choice instead.
The two pull requests could coexist, but it seems to me things would be rather messy
if we merged them, with a few ad-hoc solutions to the problem of choosing the
default value for a dimension, and possibly others to come, including;
  • fixed value for vectors, time and custom dimensions too
  • min/closest to the zero (or other reference point) as the default value for elevation
I’m wondering about having a more general solution then, one in which the two above
patches could be seen as plugins, delivering exactly the same functionality, but
with the option to grow the set of “default value selectors” without having to also grow
the number of ad-hoc changes around.
Idea:
  • Following pull 430 approach, but making it more general, create a new DefaultValueStrategy,
    which can be used to compute the default value for a given combination of dimension type and layer.
    The interface would look something like the following:
    interface DefaultValueStrategy implements Serializable {
  • Gets the actual value given the resource, the dimension, and the selected values for the already processed dimensions
Object getDefaultValue(ResourceInfo resource, DimensionInfo dimension);
  • Returns the capabilities representation of the default value. For example, it could be “current”
    String getCapabilitiesRepresentation(ResourceInfo resource, DimensionInfo dimension);
These objects would become part of the DimensionInfo, and would be serialized with XStream along with
all the state they need to perform the computation:
interface DimensionInfo {
DefaultValueStrategy getDefaultValueStrategy();
void setDefaultValueStrategy(DefaultValueStrategy);
and the xml could end up looking something like (having the proper xstream aliases registrations)
for fixed value choice:
true att LIST EPSG:5030 m 123
or something like this for represting current with the nearest value to the time of the request (which
does not need any inner field):
  • In order to locate and create the strategies depending on the current combination of resource and
    layer we’d have factories registered in the app-context:
interface DefaultValueStrategyFactory {
  • Returns a strategy, or
    DimensionDefaultValueStrategy getStrategy(ResourceInfo resource, DimensionInfo dimension);
The code implemented by the two pull requests could keep on working as it does now, being layer
specific, or dimension specific, but this would leave us the option of adding more and increase the
generality in the future
  • Finally, have the GUI use the above factories to locate the strategies usable for the current resource
    and dimension, presenting a drop down, and go back in the app context to find panel implementations
    that can handle the configuration of a certain strategy, if a GUI is needed at all:
interface DefaultValueStrategyPanelFactory { // all right, ugly name, suggestions??
FormComponent createUIForStrategy(ResourceInfo resource, DimensionInfo di, DefaultValueStrategy strategy);
Opinions?
== GeoSolutions will be closed for seasonal holidays from 23/12/2013 to 06/01/2014 ==
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
I agree that considering a unified approach for these two WMS dimension pull requests could add value. And as you mention, it could be good for later similar pull requests as well.
Jeffrey Wood
Software Engineer
Geocent
Email: jeffrey.wood@anonymised.com
Ph (BR): 225-214-4346
Idea:
true
att
LIST
EPSG:5030
m
123
true
att
LIST
EPSG:5030
m
Opinions?
Ing. Andrea Aime
@geowolf
Technical Lead
Hello,
I'm the author of the mentioned pull request 430, and I'm liking the
generalisation of my original idea as proposed by Andrea. I dare not go deep
into implementation details, because while being an happy user on Geoserver
I have only limited experience for creating code for the project.
What kind of implementation plan and timeline would you see for do for this
kind of change in the Geoserver functionality? My client, the Finnish
Meteorological Institute, is already waiting for this fix, and I'm likely to
be able use some working time on this in yearly 2014 (Jan/Feb). They would
like to see a backport also in the 2.4.x branch, and perhaps even 2.3.x
branch if possible.
Ilkka Rinne
Founder, Chief Technology Officer, Spatineo Inc.
Email: ilkka.rinne@anonymised.com<mailto:ilkka.rinne@anonymised.com>
Skype: ilkka.o.rinne, phone: +358 50 523 8974
Linnankoskenkatu 16 A 17, FI-00250 Helsinki, Finland
www.spatineo.com<http://www.spatineo.com>,
twitter.com/#!/spatineo<http://twitter.com/#!/spatineo&gt;
Google+ google.com/+Spatineo<https://google.com/+Spatineo&gt;
www.linkedin.com/company/spatineo-inc<http://www.linkedin.com/company/spatineo-inc&gt;
geowolf wrote
Idea:
* Following pull 430 approach, but making it more general, create a new
of
       * Gets the actual value given the resource, the dimension, and the
dimension);
       * Returns the capabilities representation of the default value. For
example, it could be "current"
<dimensionInfo>
<enabled>
true
</enabled>
<attribute>
att
</attribute>
<presentation>
LIST
</presentation>
<units>
EPSG:5030
</units>
<unitSymbol>
m
</unitSymbol>
<defaultValue>
<userProvided>
<value>
123
</value>
</userProvided>
</defaultValue>
</dimensionInfo>
the
<dimensionInfo>
<enabled>
true
</enabled>
<attribute>
att
</attribute>
<presentation>
LIST
</presentation>
<units>
EPSG:5030
</units>
<unitSymbol>
m
</unitSymbol>
<defaultValue>
<currentNearestRequest/>
</defaultValue>
</dimensionInfo>
* In order to locate and create the strategies depending on the current
  layer we'd have factories registered in the app-context:
      * Returns a strategy, or
it
* Finally, have the GUI use the above factories to locate the strategies
needed at all:
suggestions??
Opinions?
View this message in context: http://osgeo-org.1560.x6.nabble.com/Managing-default-value-in-wms-dimensions-starting-to-get-a-number-of-ad-hoc-solutions-tp5095644p5095689.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
On Sat, Dec 28, 2013 at 7:22 PM, ilkkarinne <ilkka.rinne@anonymised.com>wrote:
Hello,
deep
to
branch if possible.
Thanks for the interest. The timeframe is not clear, we need feedback from
the other core developers, and this might be a bit hard now that we're
in holidays.
However... this is also the best time for me to help, Jan 7 I'll be back
working
full time and at that point I'll only be able to help during weekends....
so it would
really be great if other PSC (Project Steering Commitee)
members could chime in and comment on this topic soon, as I'd be happy to
help.
A backport on the 2.4.x series is probably out of the question due to
project rules:
* a new feature has to be vetted by core devs before being added to the
development
  series
* that feature has to stay one month on the dev series before being
backported on the stable
  branch, after a positive vote from the PSC, that deems the feature useful
and not
  potentially harmful to the stability of the stable branch
* the backport has to be done at least two weeks before the release (which
happens once
  a month)
Now, the 2.4.x series will only have two more releases, Jan 18 and Feb 18,
then it will
end and the 2.5.x series will be branched off the dev branch (so, it will
become the new
stable series, whilst the dev branch will welcome the work target for
2.6.0, to be
released in Sept 2014).
However... I don't see the above as a big problem, you're free to apply the
patch to your fork of the
project and have FMI use them (same goes for the 2.3.x series, which has
been
dead for 4 months now).
*== GeoSolutions will be closed for seasonal holidays from 23/12/2013 to
06/01/2014 ==*
Ing. Andrea Aime
@geowolf
Technical Lead
GeoServer core developers… anyone with an opinion?
At this point it’s late and we’re not going to make the feature freeze (which is a pity)
but I don’t want to let drop this one drop.
And btw, even an opinion like “apply the patches as is, we’ll fix the mess later” is not out of the table,
I don’t like it personally, but I hate to have people try to contribute and giving them the could shoulder
more…
On Sat, Dec 28, 2013 at 9:16 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
== Our support, Your Success! Visit http://opensdi.geo-solutions.it for more information ==
Ing. Andrea Aime
@geowolf
Technical Lead
On Sat, Dec 28, 2013 at 7:22 PM, ilkkarinne <ilkka.rinne@anonymised.com> wrote:
Hello,
I’m the author of the mentioned pull request 430, and I’m liking the
Meteorological Institute, is already waiting for this fix, and I’m likely to
branch if possible.
the other core developers, and this might be a bit hard now that we’re
in holidays.
However… this is also the best time for me to help, Jan 7 I’ll be back working
full time and at that point I’ll only be able to help during weekends… so it would
members could chime in and comment on this topic soon, as I’d be happy to help.
A backport on the 2.4.x series is probably out of the question due to project rules:
  • a new feature has to be vetted by core devs before being added to the development
    series
  • that feature has to stay one month on the dev series before being backported on the stable
    branch, after a positive vote from the PSC, that deems the feature useful and not
  • the backport has to be done at least two weeks before the release (which happens once
    a month)
Now, the 2.4.x series will only have two more releases, Jan 18 and Feb 18, then it will
end and the 2.5.x series will be branched off the dev branch (so, it will become the new
stable series, whilst the dev branch will welcome the work target for 2.6.0, to be
However… I don’t see the above as a big problem, you’re free to apply the patch to your fork of the
project and have FMI use them (same goes for the 2.3.x series, which has been
Ing. Andrea Aime
@geowolf
Technical Lead
FYI: I have been working on the refactoring of my original pull request with a more generic approach following the outline of Andrea’s approach, I’ll probably get it finished by the end of this week.
See https://github.com/geoserver/geoserver/pull/430#issuecomment-32161840
Ilkka Rinne
On Sun, Jan 12, 2014 at 8:21 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
more…
Ilkka Rinne
Founder, Chief Technology Officer, Spatineo Oy
Email: ilkka.rinne@anonymised.com…3889…
www.spatineo.com, twitter.com/#!/spatineo
Ing. Andrea Aime
@geowolf
Technical Lead
Hello,
branch if possible.
in holidays.
    series
    a month)
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Andrea, all,
Please check the latest version of the dimension default value pull request, the code is now in pretty good shape from my part. In addition to what was discussed earlier I’ve also added fields for the default value settings in the Dimension Editor UI.
See the details on what has been done at https://github.com/geoserver/geoserver/pull/430#issuecomment-34445447
Andrea: do you think the implementation is at least roughly following the idea you had in mind for solving this issue?
I see one possible performance problem in this solution: as the default values for each layer and dimension is now resolved using the actual domain values in most cases, this might make the GetCapabilities request slower to produce if the values have to be retrieved form the disk/database.
Ilkka Rinne
On Mon, Jan 13, 2014 at 3:33 PM, Ilkka Rinne <ilkka.rinne@anonymised.com> wrote:
Ilkka Rinne
Ilkka Rinne
more…
Ilkka Rinne
On Sat, Dec 28, 2013 at 9:16 PM, Andrea Aime <andrea.aime@anonymised.com…1268…> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
Hello,
branch if possible.
in holidays.
    series
    a month)
Ing. Andrea Aime
@geowolf
Technical Lead
On Fri, Feb 7, 2014 at 4:26 PM, Ilkka Rinne <ilkka.rinne@anonymised.com>wrote:
Hi Andrea, all,
what was discussed earlier I've also added fields for the default value
Hi IIkka, yes, this is what I had in mind. Thanks for the screenshots and
the configuration examples.
Still haven't had time to look into the code diffs.
The amount of changes is large, we'll need a GSIP, I'll help preparing one
once the feature freeze is over (less than 10 days now)
Yes, unless the administrator uses only FIXED strategies of course.
I have not looked at the code yet, but for database usage one can get it to
work "quick" using two queries, one that selects
the max of the values lower than the reference, and one that selects the
min of the values highest than the reference, and then
pick the closes of the two (which I believe could be expressed with a
single complex query to, but we don't have the luxury
of writing direct SQL, whilst query + min/max visitors can be encoded
against all data sources... and it would be good to
know if we are playing against a db or not too, since a single pass through
all the data if faster against any other data source
instead, especially those that cannot do sorting...)
more information ==
Ing. Andrea Aime
@geowolf
Technical Lead
On Mon, Feb 10, 2014 at 10:31 AM, Andrea Aime
Sounds good. The refactoring of my original proposal into a more generic
solution with Spring-injectable strategy implementations resulted in quite
a few new classes, and the presentation of default values in the
capabilities meant that a few changes also had to be made in those parts.
However, I think the end result fits well into the Geoserver architecture
and makes it easier to extend the dimension support in the future.
BTW: I believe that the changes made here, namely in finding the nearest
and "current" values from the dimension domain, would also make it
relatively easy to implement support for the "current" and "nearestValue"
attributes in WMS 1.3.0 Dimension elements ("current" and "nearestValues"
for WMS 1.1.1 Extent elements). This is obviously another issue to be dealt
with and it may not make sense to mix this in the soup at this point.
Using the NEAREST strategy for TIME dim and "current" as the reference
value should also be as fast as before for producing capabilities, as it's
not resolved at this point.
to work "quick" using two queries, one that selects
through all the data if faster against any other data source
Ok, waiting for your input (and that of the other core developers) in this
matter. I've not tried to to do any new optimizations in the code yet.
Ilkka
Ilkka Rinne
On Mon, Feb 10, 2014 at 10:31 AM, Andrea Aime <
The GSIP 108 has now been created for this proposal, please review and
comment. It should now include all the relevant links and overview of
proposed implementation.
Ilkka Rinne
Sorry,
a link would be nice, I assume: http://geoserver.org/display/GEOS/GSIP+108±+Customizable+dimension+default+values+for+WMS+layers#GSIP108-CustomizabledimensiondefaultvaluesforWMSlayers-Links
Ilkka Rinne
On Tue, Mar 18, 2014 at 4:10 PM, Ilkka Rinne <ilkka.rinne@anonymised.com> wrote:
The GSIP 108 has now been created for this proposal, please review and comment. It should now include all the relevant links and overview of proposed implementation.
Ilkka Rinne
On Mon, Feb 10, 2014 at 10:31 AM, Andrea Aime <andrea.aime@anonymised.com68…> wrote:
Hi IIkka, yes, this is what I had in mind. Thanks for the screenshots and the configuration examples.
The amount of changes is large, we’ll need a GSIP, I’ll help preparing one once the feature freeze is over (less than 10 days now)
Renamed it GSIP 109 (108 was already taken by a completed proposal) and started a separate thread for discussion and votes
On Tue, Mar 18, 2014 at 3:11 PM, Ilkka Rinne <ilkka.rinne@anonymised.com> wrote:
Sorry,
Meet us at GEO Business 2014! in London! Visit http://goo.gl/fES3aK
for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Ilkka Rinne
Ilkka Rinne
